9 posts / 0 new
Last post
admin's picture
Last seen: 1 day 2 hours ago
Silly Question?
Am i right in thinking that to use BD-Live on your Blu-ray player you need to have the pc turned on, or can the player connect itself as long as the wireless router is turned on?
Andrew Everard's picture
Last seen: 3 years 3 months ago
Re: Silly Question?
You don't need a computer, but you do need a connection to the router. Standalone BD players have an Ethernet port, not wireless, so you need to add an Etrhernet bridge to connect wirelessly to a router.
Anonymous's picture
Re: Silly Question?
So if i hard wire it into the router and turn it on the blu-ray player will connect to the internet?
John Duncan's picture
Last seen: 4 days 22 hours ago
Re: Silly Question?
Pretty much, provided there's nothing weird going on at your router like having DHCP turned off or MAC Address filtering or blah blah. Try it first and if it works, there you go, if not, come back.
Moderator: john.duncan.whf at gmail dot com
System burgeoning
Anonymous's picture
Re: Silly Question?
Thanks will try it tomorrow need a cable. Do i want a straight network cable or a crossover network cable?
fatboyslimfast's picture
Last seen: 9 months 1 week ago
Re: Silly Question?
Straight - x/o are only if you want to connect two computers and don't have a switch/hub/router in the middle.
Anonymous's picture
Re: Silly Question?
Thanks will give it a go.
The_Lhc's picture
Last seen: 1 month 4 weeks ago
Re: Silly Question?
Oh to answer your original query: yes it was! Wink
Re: Silly Question?
the_lhc: Oh to answer your original query: yes it was! Wink
So not needed, the_lhc...
Log in to post comments
