PowerLine - can be used anywhere?
5 replies [Last post]
El Hefe
El Hefe's picture
Hi all,
In the May issue, I read about the PowerLine network via existing power cable around the house. Does this work in any type of house or any type of power cabling ie. Will it work in Malaysia for instant?
If yes, which model would you recommend. Requirement is quite simple:
1. My wifi router is in the living hall downstairs
2. I need an 2 ethernet cables for the upper floor because the wifi signal is not strong enough. Need one for my laptop in my hifi room and the other one is for my LED TV both on the upper floor.
Can the PowerLine be used via an extension cable ie: a Belkin 8 way extension? Or it needs to be plugged direct to the wall socket?
Appreciate any feedback.
__________________
HiFi: ClearAudio Concept TT, Musical Fidelity M6i and M6 DAC, M1s (CDT, CLiC, ViNL), Onkyo TA2600, SONY MDSJA20ES MDP, ProAc D18 with full Siltech cabling.
HT: Samsung UA55B7000 LED, OPPO BDP 95-EU,Marantz DV4003, Yamaha RX-V2067, Philips DVDR7300H, Infinity Primus Center, Wharfedale WH2, SW15 Sub, Mission M34i with full QED cabling
Bedroom: BRIK Audio BT Stage, Bose WAVE Music Sytem III
HeadFi: Alessandro Grado MS Pro, Bryston BHA-1 headphone Amp.
Office: iTunes, UD100 USB DAC, Bose Companion II, Musical Fidelity HPA headphone amp, Bose Over The Ear
visionary
visionary's picture
RE: Wi-fi
The one I use is a Panasonic equivalent and it specifies that you should plug it in direct to the socket and not via an extension. Are you on 220v in Malaysia? I'm sure, if they are selling similar products there, that they will work OK.
Better, if you can, to run a cat5 cable upstairs.
__________________
Sonos ZP90>Missing Link "Digit">Dacmagic>Chord Cadenza>Leema Tucana I>Van Damme UP LC-OFC>ATC SCM40s
El Hefe
El Hefe's picture
RE: Wi-fi
Malaysia power supply us at 235 to 240 V at 50 Hz. Mind to share thw panasonic details? What is the commercial name?
__________________
El Hefe
El Hefe's picture
RE: Wi-fi
Any other takers?
__________________
visionary
visionary's picture
RE: Wi-fi
Sorry for the delayed response.
It's a Panasonic BL-PA 100 but as far as I can find out they no longer manufacture it. It wasn't compatible with the Powerline products and so you need to look for one of them, I think
__________________
El Hefe
El Hefe's picture
RE: Wi-fi
Thanks visionary.
Sorted. I purchased 2 homeplug converters (Edimax brand), and my internet connection on the 2nd floor is really fast now. It worked like magic Smile
__________________
