8 posts / 0 new
Last post
admin's picture
Last seen: 3 days 17 hours ago
Netgear router
Is playing up and having to re-boot alot,what would be a good upgrade replacement for this.
Murray
John Duncan's picture
Last seen: 1 month 2 weeks ago
Re: Netgear router
Hold fire, buddy. Not sure a replacement would fix it - you may have issues elsewhere, particularly if you've added anything to your network recently? I just added a STB to my network and I started to lose my nework all the time. Seems to have settled down now though.
What's your current setup (PC included), and have you added anything recently? Is it a 'b', 'g' or 'n' router?
Moderator: john.duncan.whf at gmail dot com
System burgeoning
Anonymous's picture
Re: Netgear router
I dont know John,just the standard one supplied by sky,nothing been added recently either,but recently downloaded safari 4 and seems much slower and together with flashing icons on router was wondering if safaris probs were a router prob.
Murray
margetti's picture
Last seen: 1 year 7 months ago
Re: Netgear router
What's it like with another browser?
Too early to do so yet (before eliminating other possibles) but Netgear routers do seem to like a "reset to factory defaults" every so often - in my experience at least!ÿ
Re: Netgear router
blackcabmal:
Murray
You've got a Mac right? I'll come back to you with some tips in a while, got some stuff to do.
System burgeoning
Anonymous's picture
Re: Netgear router
Yeah iMac
cheers
Sc00bied00's picture
Last seen: 3 years 1 month ago
Re: Netgear router
margetti:
.... but Netgear routers do seem to like a "reset to factory defaults" every so often - in my experience at least!
Hmm, my gd old mum has a netgear supplied by sky when she switched over and in the last 18 month has never needed a reset, however it not to say that this would not help. I would try removing the power from the router for a couple of minutes and reconnect, simply a reboot to the router, settings remian in tact. Are you sure nobody in the area is on the same channel as you ? e.g channel six, try changing this to a different one to see if it helps. It might be better to set the router to receive both B/G signals rather than B or G, it will allow it to cope with anything that may cause interference. I use a Linksys my self and a reboot now and again helps 10 fold, the electronics are given a chance to cool and once powered back on its happy as larry down the local.
HTH - sc00bie
SpiceWeasel's picture
Last seen: 3 weeks 18 hours ago
Re: Netgear router
Have you tried ringing BT so they can do a check on your line ? If thats ok I would ring up your ISP and see what they say.
I have a Netgear router and for a few months kept getting disconnects/loss of connection. Turned out that my ISP was messing about switching/upgrading to new servers so the connection was a bit flaky for a while.
Have you checked to see if theres a firmware upgrade for your router ?
Log in to post comments
