Need motherboard for Quad core AMD?
Hey
I bought a cheap barebones bundle, only to find out they cheaped out on EVERYTHING.
The motherboard is very basic and only has 10/100 lan, and can only accept ddr2, which to get 4gb ram is turning out to be expensive.
I want to get all my stuff gigabit ready and ddr3, can you recomend a good motherboard.
I do not want to spend lots, cheaper the better, as I dont do much with my PC.
AMD Phenom 9350e
Board: ECS GeForce6100PM-M2 7.0
Broadcom AC131 10/100 Lan Phy
Sorry I stream media. Hi-def files.
LOL
Would this work:
http://www.diskdepot.co.uk/acatalog/tp-link-pci-gigabit-ethernet-pci-network-interface-card-101-mte088.htm#aAU_2dMTE088
this is the updated version of that gigabit card. Supports jumbo frames
http://www.diskdepot.co.uk/cgi-bin/ss000003.pl?SS=tplink+3269&ACTION.x=8...
4GB DDR2 costs around £55. Just changing to DDR3 wont make it go any faster by itself. (You may see a 5% increase maybe).
- Login to post comments
Canada, if you don't really do much with your PC, keep what you've got, disable the on-board LAN in the BIOS and buy a PCI LAN card that meets your needs.
LOUNGE: SONY KDL-46W4000; STR-DA2400ES & BDP-S350; SKY+; TOSH SD3010 DVD; PIO PD-F1009 MULTI CD; WII; KEF CRESTA 2 fronts,CRESTA 1 rears CRESTA CENTRE; BUDGET INTERCONNECTS & 79/42 STRAND OFC SPEAKER CABLES BEDROOM: PANA TH42P-WD6;
