Need Help up wireless network!
4 replies [Last post]
Davro83
Davro83's picture
Hi, ok i have just bought a belkin wireless router so i can have my laptop and xbox wireless. Im having trouble. When installing, it aks what type is my network?......static, dynamic, pppoe or pppoe? What does this mean? What do i choose?
I randomly chose dynamic and installed it. Ok now it all connects to the net but then loses connection. On my xbox It connects but after about a minute i lose signal, it then re-connects and then a minute later loses signal again. Also happens sometimes on my laptop. Does anyone know why? Really need help.
james9002uk
james9002uk's picture
Re: Need Help up wireless network!
What type of router is it? Netgear? model?
Are you on XP or Vista?
What is the signal strength when you are using it? ie how far away are you from your router?
Laptop - USB dongle or PC - network card?ÿ
professorhat
professorhat's picture
Davro83:
This refers to the type of connection your ISP provides you - you should give them a call and they will be able to tell you.
ÿ
Davro83
Davro83's picture
Its a Belkin router and i use Vista. The strength is full, i only sit 2 metres away from router. The laptop has stopped losing connectionn now but i cant watch any videos or play anything like poker online. If i watch something off you tube or something it only plays for about a minute then stops. And when i try to play poker online it just cant connect, yet looking at normal web pages is fine. Im very confused.
professorhat
Did you check with your ISP that Dynamic was the correct setting?
ÿ
