N or G network
6 replies [Last post]
Chisy1
Chisy1's picture
My current set up is to create a wifi network using an airport express, however it is only an 802.11G spec (i.e. old).  My iMac is also old too and only has a 'G' card in it.  However, my apple tv and ipad are 'N' capable.  I have a new airport express which I set up to join the existing network.  It could create a 'N' based network if I connected it to the modem.
So, if I swapped the AEs around would i have an N network but what happens to my imac and old AE ...would i still be able to connect by wifi?   I could probably retire the old AE, because I could stream to my hifi using the Apple Tv rather than AE, so my main concern is my computer.
Connecting around the house is generally okay but there are patches where its occassionally a bit dodgy and its becoming more regular for family to be connecting to internet / NAS on multiple devices so I would like things to be as robust as possible but obviously don't want to stop certain things working!!
(I did see some cheap software that turns certain old iMacs into N capable but mine is SO old that software isnt compatible!)
thanks for the assistance
Chisy
Paul.
Paul.'s picture
RE: N or G network
When you say you have a new AE, does that mean the one released a few days ago that looks like a white Apple TV?
__________________
Paul's BR/805 system thread
(where the photos live) Paul's Flickr page
Chisy1
Chisy1's picture
RE: N or G network
Sorry, should have been clearer, its the old design that plugged directly into the wall socket.
professorhat
professorhat's picture
RE: N or G network
My understanding is, you will be able to connect your iMac to the wireless, but it will slow everything else on the network down when it is.
cheyworth
cheyworth's picture
RE: N or G network
if you get something like this
http://www.netgear.co.uk/home/products/wirelessrouters/ultimate-performance/WNDR4500.aspx#two
you could create a second wireless network (one G one N).
as long as the as both are connected to the NAS by cable then you should be fine.
__________________
Source: Marantz BD5005 & PC into V-Link into a Musical Fidelity KW DM25 DAC. Project RPM4/2M RED, speed box.
Amplification: Onkyo TX-NR818 A/V only, MF KW500 (JS mod), Arcam P7.
Speakers: Monitor Audio PL300, GS-LCR, GS-W12, GS-FX, Silver FXi. TV: LG 50PK350/Sky HD. Cables: Van Del Hul, Chord. Also: Little Dot mk V
scene
scene's picture
RE: N or G network
That's pretty much what I've done, albeit with the older wndr3700 and it works a treat. The two different wifi networks keep everything tidy and the nas is hard wired to the gigabit backbone.
__________________
Hi Fi: Arcam A85, DV88 (CD only), Project Debut II, AE Compact-1. AV: Arcam AVR250, DV79, Sony BDP-S760, Monitor Audio Silver 8i, RS-LCR, RXFX, Sonos ZP90, Pioneer KRP500A. 2nd AV: Pioneer SX-SWR2, Dell Zino HD, KEF KHT2005.2 eggs, Sonos ZP90. That Cable HDMI, Chord Crimsons and Sonos ZPS5s everywhere & a spare Yamaha RXV-667!
cheyworth
cheyworth's picture
RE: N or G network
You just need to make sure the G devices only connect to the G network.
Chris
__________________
