MP3 or AAC for streaming from Revo Mondo wifi radio?
5 replies [Last post]
whiskywheels
whiskywheels's picture
I guess it's AAC, as the display shows that it's got more Kbs than MP3? As our FM signal is very poor here, I've been forced into getting one of these reasonably priced devices to listen to Radio 3 on my hifi. Is this the highest quality stream I can get or are there other devices or methods I should try? Any comments, suggestions or advice much appreciated as I'm new to this whole area of streaming/internet radio or whatever it's called! Wink
noogle
noogle's picture
RE: MP3 or AAC for streaming from Revo Mondo wifi radio?
I think the standard Radio 3 internet stream that you are using is 192kbs.  The Radio 3 HD stream is 320kbs - you could pick this up via a netbook or laptop.  For best quality, use a stand-alone DAC with the laptop (e.g. DacMagic).
__________________
QuietPC JRMC SeeDeclip NAC252 Supercap NaimDAC XPS NaimUniti NAP250-2 Ovator S400s
whiskywheels
Thanks Noogle. The Revo's displaying 328Kbs for Radio 3 (using AAC), so I guess that's as good as it gets? Although I sometimes use my netbook to play FLAC files, connected to the DAC (Audiolab 8200CD) via USB, I prefer not use it for radio; it seems a bit of a faff on a daily basis to fetch it from another room, wait for it to boot up etc. etc.
noogle
noogle's picture
Sounds like you've got the R3 HD stream (although I'm surprised it doesn't say HD).  The gotcha in your current setup is that you're using the Revo Mondo's built-in DAC, which probably isn't very high quality.  Might be worth trying out the laptop and Audiolab DAC just to see if it sounds better.  I agree about the faff element with using a PC - I have a PC permanently on and wired into my system.
__________________
whiskywheels
I've just done a quick comparison, and can't really hear any discernible difference between the Revo and the Audiolab embarassed I'll probably not bother with a more thorough test, as my crummy old laptop is quite noisy so, until I get a new one.........
whiskywheels
465Kbs streaming on Radio 3 today! It's been working really well since choosing AAC over MP3 option, but there's nowt in the instructions about this, so I've still no idea what the difference is in technical terms.  It's all a mystery, trial and error, and no help at all from the manufacturers, suppliers, or the so-called instructions. banging head against wall
(this refers to my internet purchase; had I bought from a human I could at least visit the store and ask them. Although in practice I've often found store staff to know less than I do after 10 mins 'research' on t'internet!)
