iPhone to PC connection
5 replies [Last post]
Cofnchtr
Cofnchtr's picture
Hi, I have an iPhone 3GS which I have enabled wi-fi and use my home network. I want to take some pictures from the PC to the iPhone - can I only do this via itunes or should I be able to do this over the network? Is there something I am not enabling on the iPhone for it to 'see' the contents of my PC or vice-versa? Cheers, Cofnchtr.
__________________
Panasonic TX-50GT30B | Pioneer VSX-LX53 | Pioneer BDP-LX54 | B&W M1 x 5 | REL Strata | SKY+HD 1TB | Harmony One Remote | Contentment.
professorhat
professorhat's picture
Re: iPhone to PC connection
Depends on how you want to view them. If you want the pictures to appear in your Photos section, I think the easiest way is via iTunes. If you just want them available on your iPhone, you can use something like the File Magnet or Air Sharing apps (there may be others, personally I use File Magnet).
Cofnchtr
Cofnchtr's picture
Ta. Wasn't sure if I was missing something in that I could browse my PC from my iphone.
I also have a wi-fi printer that my phone can't 'see' - presuming 'there's an app for that'
Cheers,
Cofnchtr.
__________________
Cofnchtr
Cofnchtr's picture
Found out there's an app for that right enough.
Canon have an app that covers my printer - just trying it now although it's detected the printer it doesn't print anything...
Edit: Got it to print but after a lot of faffing about - keeps trying to connect to the network although it already is by default...
Cheers,
Cofnchtr.
__________________
francisjohonson
francisjohonson's picture
Mine, i just use the cable.
Fisherking 145
Fisherking 145's picture
The Plug Player App let's you browse PC's that are on your network, allowing you to view pictures and play music.
__________________
Audiolab 8200CDQ Roksan Caspian M2 Power Amp Dali Ikon 6
Sony KDL46HX853 Humax Fox T2 HDR Sony BDP S570 Yamaha RX 3010
Other Stuff - HP Data Vault Squeezebox Touch Asus Xonar Essence AKG K271 JRiver Media Center
