3 posts / 0 new
Last post
ziggy47's picture
Last seen: 2 years 3 months ago
How to listen to my laptop/iPhone music......
Hi, back again for more help and advice......... This time I need some help how to get my iPhone and laptop music to play through my 5.1 system. The system is a Sony DAVIS 10 and I would like to play my laptop iTunes library principally through it, when using the laptop in the lounge, which is not where my hifi is located. Don't know if I need AirplayAppleTV etc etc.....totally lost...... Any help would be, as usual, very welcomed. Cheers in anticipation...........Richard.
ziggy47's picture
RE: How to listen to my laptop/iPhone music......
Bump..............
nads's picture
Last seen: 6 months 1 week ago
Well yo have 3inputs so either find some thing to play the music tha will plug in or find some thin that will send the audio from the pc to the amp or just plug the phone in directly or via a dock.
Option
Squeezebox.
A 3.5mm to phono cable.
Some wifi senders ( will need power at the hifi end)
Plus about 501 other options.
You need to define what you want to do and how much you want o spend.
Log in to post comments
