How to create wifi in my shed?
18 replies [Last post]
Woodchippie's picture
I am looking to create wifi in my workshop down the garden.
I have some netgear Ethernet adapters that plug into the mains sockets.
If I plug an old netgear wireless router into the the plug with Ethernet cable would that create wifi in my workshop.
If not how could I do it?
__________________
Rega RP3,Rega Brio r, Rega Dac, Rega ear headphone amp, B&W 685 speakers, apple airport express-toslink.
various quality cable What HiFi awards.
scene's picture
RE: How to create wifi in my shed?
That could work - assuming the ethernet over mains adapter requires nothing special to be installed on the device it's being plugged into. If it does, might be a non-starter and you might need a PC to act as a bridge between the homeplug and wifi router. Remember:
1. Plug the home plug into one of the four LAN side ethernet ports on the router (not the WAN side)
2. If you have another router already at home (you probably will have) that assigns IP addresses, then make sure your WiFi router isn't trying to assign addresses as well.
__________________
Hi Fi: Arcam A85, DV88 (CD only), Project Debut II, Sonos ZP90, AE Compact-1.  AV: Arcam AVR250, DV79, Sony BDP-S760, Monitor Audio Silver 8i, RS-LCR, RXFX, Sonos ZP90, Pioneer KRP500A.  2nd AV: Pioneer SX-SWR2, Dell Zino HD, KEF KHT2005.2 eggs, Sonos ZP90.  Cables: That Cable HDMI, Chord Crimsons, CAT6 backbone  Sonos S5s in the bedrooms
expat_mike's picture
Just to clarify the question, you are seeking to create wifi inside your shed, rather than a wifi link from your house to your shed?
__________________
Lounge - Arcam Solo Neo, Partington Super Dreadnought, Monitor Audio Silver RX1, Panasonic DMP-BDT310, Samsung UE46D6530, Yamaha RX-A1020
Legacy - Rotel-RA820, Wharfedale Diamond 1, Philips CD104, Akai HX-R44, Sony ST-313L
Paul.'s picture
Is your shed power sockets on the same ring main as the wireless router in your house?  As long as they are, your plan should work.
__________________
Paul's system thread
(where the photos live) Paul's Flickr page
bigboss's picture
Online
Or you could get a wifi extender.
__________________
To explain further.the shed is 50 metres away from the house, mobile phone signal is rubbish so I thought I would attempt wifi to keep in touch with the world.
i have an old Netgear router with wifi and some netgear home plugs, that I no longer use, as the house is all Apple extenders and expresses.
The shed is on the same electic as the house not on the same ring though, it has its own fuse board, that's connected to the fuse board in the house.
__________________
__________________
john1000000boy's picture
Fwiw I use develo home plugs in my settup....  The sky bb comes into 1 house and then home plugs into the mains and passes through to the sitting room....which is in the next door house, on a different fuse box and supply.  I receive 2 electric bills for the 2 halves of the house.  I was thinking about this also, so
Broadband router > home plug > extension lead > home plug> wifi router in shed/garden
I cannot see why this would not work??
Have often thought about trying it to get AirPlay outside.
Let me know how you get on...
John
__________________
Panasonic Tx-P65ST50B. Pioneer SC-LX82, Pioneer BDP-LX52, Pioneer PDP-4280XD. Monitor Audio Rx6 Av12. Apple Macbook, Apple Ipad air 64gb, Apple iphone 4 8gb, Apple Ipod Touch 32gb, Apple Time Capsule 2tb, Apple TV. Sky HD. Microsoft Xbox 360. Monster Beats Studio HD. Sennheisser CX 300 II. QED Silver Spiral, QED Anniversary XT Speaker Wire, QED HDMI-P. One For All Xsight Touch. Belkin N Router. Devolo Home Plugs. Buffalo linkstation live 2.0Tb. Iomega 1.5tb Hard Drive. Spotify Premium. Philips Fidelio AirPlay spkr dock
My System Thread Best pics start on Page 4:
http://www.whathifi.com/forum/your-system/finally-my-new-system-as-ofnow
daveh75's picture
Online
Modern Homeplugs don't need to be on the same ring main, just the same CU/fuseboard
__________________
OK, my next question would be, how do I set up router with no computer? Or do I set it up on my computer before I put it in shed,
password setup etc.
__________________
yes correct, I could buy another apple extender perhaps and use the home plugs to get the Ethernet. But I want to do it with an old router, to save some money.
__________________
daveh75's picture
Online
There's no problem using an old router as an AP. At the least you'll just need to disable DHCP (and let your main router serve up IP addys) and at the most you'll need to change it's IP to one that's outside your main routers DHCP pool, but still within the same subnet.
__________________
scene's picture
Which is what I was trying to say - very badly! I use my old netgear router as a pure wifi bridge in this way and it works very well indeed - it's now actually more stable having been relieved of the extra strain of WAN, DHCP, etc. duties.
__________________
I have installed the home plugs and they are communicating..Great
I have reset the Netgear router and plugged it in  and it creates wi-fi...great
My iphone picks up the signal but when I try to use it it says network error...problem
I have plugged the router into a laptop in the house and the bt cable into it, and brought up the netgear web address page for settings,
what settings do I adjust to get it to work?
__________________
beauty, eh
At last...
all working without the Network router though, forgot I had a spare Airport express so using that.
I love apple products, they just work.
Thanks to every body for there comments, I am very happy now that I am not so isolated in the workshop.
No need to go to the house now. man cave complete. For now anyway..
__________________
scene's picture
For the record, what model of NetGear router is it?
1. Ensure you've haven't plugged the ethernet cable from the homeplug into the "INTERNET port" (as the NetGear manual calls it) - this won't work. You need to plug into one of the other four ports and use it as a WiFi switch.
2. Disable DHCP by going to the LAN IP menu and unchecking "Use router as DHCP server"
3. If your main router has an IP of 192.168.1.1, you might need to change the default IP address of the NetGear router: on the LAN IP menu change change the IP address to something else, like 192.168.1.99
4. Click APPLY to save the settings.
EDIT:
Just checked - there are details of how to make this work from NetGear here
__________________
