How to connect a TV, DVD home cinema & Sky+box wirelessly?
1 reply [Last post]
ressull
ressull's picture
I am looking to buy an LCD tv, mount it on wall and link it without wires to a dvd home cinema and a sky+box in another part of the room. Firstly, can this be done. Secondly, how do i go about doing so? I'm a bit of a novice in this area so any advice will be greatly appreciated. Thanks, russell
BreatheEasy
BreatheEasy's picture
Re: How to connect a TV, DVD home cinema & Sky+box wirelessl
You can get wireless video senders though the quality will be pretty poor to be honest. And you'll need receiver box plugged in beside the TV and leads running up to it (including the power lead for the TV) so I'm presuming that's what you were trying to avoid in the first place.
The obvious alternative would be to position the dvd/sky boxes closer to the TV. If you've got a dvd home cinema set up then surely the speakers would be in the incorrect position to work anyway if they are positioned away from the TV?
Failing that a long run of cable around the skirting boards. Though I could be wrong....
