Help me find a N router or gigabit?
9 replies [Last post]
canada16
canada16's picture
Hey
 I have no idea what I am looking for, but I am trying to get myself from 10/100 to gigabit, and would like a better router.
I have a cheap sky one, and they have given me permsion to get another 3rd party router, but i have no idea what I need,.
I just bought a gigabit pci card for my pc, and getting a 8 port gigabit switch, now just want a better router.
I also need it as laptop keep dropping if you take it upstairs.
I dont have  a lot of money so cheaper the butter
__________________
Living room: Monitor Audio RX6-Centre -RXFX-
SVS PC13-ULTRA-WOW!!!!! Surprised
Onkyo TX-NR818, Panasonic 50G20, PS3, Sony BDP-370 - Macbook Pro i5 For HTPC.
BEDROOM- LG 32LE4900 Pioneer VSX-921 MA- R90HD & 225HD, RSW12
Rocky Mountain Vertex Mountain bike.
cram
cram's picture
Re: Help me find a N router or gigabit?
Why do you want a better router? Why not got with a gigabit switch that then plugs into your router.
EDIT: seen that you are getting the swtich anyway - so what's the point of the router
canada16
canada16's picture
I didnt think the sky router was that good, and because it drops signal on my laptop if I go upstairs.
But my laptop is G only as well, so I was going to put a N card in the Laptop, if I can as they seem quite cheap.
Buying the switch as might be building a HTPC or getting a gigabit streamer when ac ryan release their fluxx in march
__________________
cram
cram's picture
Ok so you are just after a better wireless connection? You could choose to replace your router with a new one or purchase a separate wireless access point.
scene
scene's picture
Actually, Wireless N may not improve the situation with your laptop upstairs. The drop off for A/N is faster than for B/G, and you may actually get a worse signal upstairs. You may want to look to get a gigabit non-wifi router and plug your gigibit switch into this. Then plug a wifi router - you might be able to use your existing one - in a more central location in the house, to maximise coverage...
__________________
Hi Fi: Arcam A85, DV88 (CD only), Project Debut II, AE Compact-1. AV: Arcam AVR250, DV79, Sony BDP-S760, Monitor Audio Silver 8i, RS-LCR, RXFX, Sonos ZP90, Pioneer KRP500A. 2nd AV: Pioneer SX-SWR2, Dell Zino HD, KEF KHT2005.2 eggs, Sonos ZP90. That Cable HDMI, Chord Crimsons and Sonos ZPS5s everywhere & a spare Yamaha RXV-667!
canada16
canada16's picture
Oh so put my sky router upstairs and have the non wifi attached to the Hifi and media area downstairs?
Can I have 2 routers in one house on the same address?
Thanks, sorry not very up with these things
__________________
scene
scene's picture
canada16:
That is a possibility - assuming your sky router has an input port (sorry, I#m being thick here - but some ADSL style routers, have a USB in and then only WiFi / RJ45 (wired) out ports - it depends on model.
No. If you want two routers, they either have to have different names - which means they will interfere, or you have to have one(Drunk that can act as repeaters, in which case they will enhance your reception.
Don't worry - I have the same problem - I've had to look into all this stuff, and found out some of it the hard (read expensive) way...
__________________
canada16
canada16's picture
Well got me a pci gigabit card for my pc and scored a new belkin 8 port gigabit switch from ebay for 16.00, but thats because I had 9.00 in ebay points, quite good really considering they are 25.00 and selling for 50.00 + elsewere, and they had tons.
Now just need to get a media streamer or htpc thats gigabit as well
__________________
john1000000boy
john1000000boy's picture
Hey Canada have you looked at broadband by mains??  I too have Sky Broadband and the signal through the house is very poor(old cottage thick walls and a long distance between amp/xbox/sitting room and where the sky broadband box is.  I simply went to Pc World and bought a Devolo broadband by mains kit and a belkin N router.  1 plugs into the sky broadband box sending the signal by mains to the other plug which is in my sitting room behind the kit rack and plugged into my N router.  Which is plugged into my amp and means the xbox and laptops all work over the wifi!  Thinking about getting an additional plug for the study for the Windows pc too.  They are good and are no problem to move about the house if you wish to say surf in the kitchen etc.  I think the N Router (with N Dongle) and the bbm kit came in at a little over £100!!
__________________
Panasonic Tx-P65ST50B. Pioneer SC-LX82, Pioneer BDP-LX52, Pioneer PDP-4280XD. Monitor Audio Rx6 Av12. Apple Macbook, Apple Ipad 3g 64gb, Apple iphone 4 8gb, Apple Ipod Touch 32gb, Apple Time Capsule 2tb, Apple TV. Sky HD. Microsoft Xbox 360. Monster Beats Studio HD. Sennheisser CX 300 II. QED Silver Spiral, QED Anniversary XT Speaker Wire, QED HDMI-P. One For All Xsight Touch. Belkin N Router. Devolo Home Plugs. Iomega 1.5tb Hard Drive. Spotify Premium. Philips Fidelio AirPlay spkr dock
My System Thread Best pics start on Page 4:
http://www.whathifi.com/forum/your-system/finally-my-new-system-as-ofnow
canada16
canada16's picture
Hey
 Are you talking about homeplugs?
I had those but they are wired, I need to sort my wires out, so I am going to tery pull the router out from the corner a bit more and see if that helps as its behind my hi-fi rack right now.
If no joy will need to look into more options.
__________________
