External hard drive/NAS for iTunes to Marantz CR603
4 replies [Last post]
hifilover1979
hifilover1979's picture
I'm very much a noob when it comes to the networking of music etc so please bear with me Tongue out
I currently have a Marantz CR603 hooked up to M/A BX5 speakers; I use iTunes via my PC for music but the computer needs to be switched on to use this facility
What I'm after is an exsternal NAS / hard-drive so that I can listen to music without having the PC switched on.
1/ Is this possible?
2/ What NAS / external hard-drive would you suggest?
Criterias would be that I'd be after 1TB od memory minimum (I've a lot of music) and also I dont want to fork out a fortune so budget ideally up to £150 (poss a bit more) max
Thanks for all/any advice Smile
__________________
Main system: Marantz CR603 (with Airplay) / M/A BX5's / Chord Odyssey 2. Office: iMAC (with iTunes) / NAD C320BEE / M/A BX1's 'My room': Cyrus StreamXP / XPower amp / x2 PSX-R's / Hark stand / M/A GX100's / Partington stands
professorhat
professorhat's picture
RE: Wi-fi
It is most definitely possible. What format is your music in e.g. Apple Lossless, MP3, AAC?
hifilover1979
RE: Wi-fi
It will all be in Apple Lossless Smile
__________________
professorhat
RE: Wi-fi
Hmm, I'm no expert on media streamers, but I can't see one which includes a hard disk and also streams Apple Lossless. I use an Apple TV (original one with hard disk), but that only has 160 GB so nowhere near your needs. It can be jail broken so that an external USB drive can be used with it, but the price combination of both these items would be well above your £150 budget - more in the region of £300 - £350 if purchased new. Unless someone has other ideas?
The other option would be to convert your music to a different form of lossless e.g. FLAC. You could then get a standard DLNA enabled NAS (plenty to choose from, but something like the Synology DS211J or Western Digital MyBooks) and stream directly from this to your Marantz.
Mr. Iceman
Mr. Iceman's picture
RE: Wi-fi
I've got Buffalo Linkstation NAS 2 x 1TB (in Raid 1) connected to my '603 via router. Transferred all my wav files onto it and streaming directly to '603 (and PS3) without any issues and it sounds great.
The relatively small screen on the Marantz may be an issue for some, when navigating through menus for NAS-based files.
Buffalo Linkstation was also reviewed by WHFSV, look it up. I can't fault it in any way.
