Can I connect an external DAC when I stream music wireless from pc to receiver?
1 reply [Last post]
J.Kratz
J.Kratz's picture
I own a Denon AVR-4308A, and I stream music wirelessly from my pc via a router to the receiver. But I really want to add an external DAC to improve the sound quality. The Problem is, i don't know how to add an external DAC to this system. Maybe you guys have some ideas?
professorhat
professorhat's picture
Re: Can I connect an external DAC when I stream music wireless f
You would basically need to add another device which could accept the wirelessly streamed music from your PC - if you're using iTunes, Airport Express is the way to go. That box could then output a digital connection to an external DAC which could then be connected into one of the analogue inputs of your Denon.
However, I'd imagine the Denon has a pretty good DAC built into it so you may have to spend quite a bit to improve on it - worth checking this out first before parting with any cash I'd say.
