18 posts / 0 new
Last post
hammill's picture
Last seen: 1 month 2 weeks ago
Can anyone recommend a wifi booster?
WiFi does not reach the back of my house, so am thinking of a booster. Does anyone have a recommendation?
Ben123's picture
Last seen: 3 years 3 weeks ago
RE: Can anyone recommend a wifi booster?
A not so tech savvy friend of mine asked me to install one in his house.  I went for the affectionaly named TP-LINK TL-WA830RE as it was only 30 notes and got good reviews.  I've given it a trial run in my house and its a big improvement over the crummy sky router i have.
Havent got round to installing it at his house yet but hopefully it will do the trick with his lead walls or whatever he has :grin:
MajorFubar's picture
Last seen: 1 day 8 hours ago
Unless you really need the WiFi I'd recommend you take a different route and buy homeplugs. It's the best thing I ever did.
Nothing truly beats connecting two things together with a cable.
Audio: MacMini / AEX > AVI DM10 + BK Gemini II sub; Visual: Samsung BD-C5500 > Panasonic TX-L47ET5B.
Head-fi: various, but most often Sennheiser HD-580 or Audio Technica ATH-M50X
hammill's picture
Thanks, I already have homeplugs which do indeed work well. My tablet, phone and son's ipod all require wireless.
hammill's picture
Thanks, but that is a bit big - I may want to deploy on the landing, so one of the plugin ones is probably more suitable. I notice on Amazon that there is a TP-LINK TL-WA850RE which fits the bill.
Ah fair do's...just thought I'd mention it in case you'd never heard of them. I hadn't heard of them 'til quite recently, nor have most of the people I know.
relocated's picture
Last seen: 1 year 10 months ago
Will an Apple Airport Express do the job?  Link it to your router and it creates another wifi zone as well as other things.  Not very cheap I suppose but I'm sure I have read that it is a solution.
Apple lossless - Netgear Nighthawk - ATV3 - AVI ADM 40.
AVI ADM 9T used in my wife's system
chebby's picture
Last seen: 1 day 7 hours ago
Apple Airport Extreme 802.11n base station.
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
Feral's picture
Last seen: 4 hours 34 min ago
Useful utility for checking if neighbours or other devices are hammering a particular wireless band.  Enables you to choose a quiet band and potentially improve performance although you may have checked this already.
http://www.metageek.net/products/inssider/
Feral
LG 65UH950V/AVR2300W/Q7000i/Synology DS213J/CA640Av2/CA640Cv2/CASM6v1/Project Debut III USB/Monitor Audio Bronze BX6
hammill's picture
Feral
I have already changed channel, but thanks for the suggestion. It is a long way from my wireless router to the back of the house.
LateDev's picture
There are devices called powerline wifi extenders, which combine the powerline technology, but the receiver also Transmits/Reveives wifi. Ideal for those with pads and game boxes with no ethernet connection.
hammill's picture
As It happens, that is what I got in the end.
Anonymous's picture
[UNPUBLISHED]
Paul.'s picture
Last seen: 4 days 23 hours ago
What router do you have?  It may be worth considering replacing the router with a better one rather than adding and extender to the network. Adding an extender can slow down the network.  I really rate Asus routers, N66 is bullet proof and very fast.
emptage's picture
Last seen: 1 year 5 months ago
Did the powerline wifi extenders solve the problem. I have similar issues
Naim Nait 5i, Naim CD5, KEFQ300, Sonos
emptage's picture
I had the problem of wi fi not reaching parts of my house.  Power plugs were not possible as some rooms on a different circuit.  I was using a Virgin Media superhub.  What I did was to use the superhub as a modem only and purchase a Netgear Nighthawk router.  This has brilliant coverage and solved my problem
Pages
Log in to post comments
