Can anyone recommend a wifi booster?
9 replies [Last post]
hammill
hammill's picture
WiFi does not reach the back of my house, so am thinking of a booster. Does anyone have a recommendation?
Ben123
Ben123's picture
RE: Can anyone recommend a wifi booster?
A not so tech savvy friend of mine asked me to install one in his house.  I went for the affectionaly named TP-LINK TL-WA830RE as it was only 30 notes and got good reviews.  I've given it a trial run in my house and its a big improvement over the crummy sky router i have.
Havent got round to installing it at his house yet but hopefully it will do the trick with his lead walls or whatever he has excellent!
__________________
Hi-Fi: Beresford TC-7520 Dac --> Marantz PM7000 Amp ---> B&W CM1
Headphone Setup: Arcam RPAC --> AKG 450
MajorFubar
MajorFubar's picture
Unless you really need the WiFi I'd recommend you take a different route and buy homeplugs. It's the best thing I ever did.
Nothing truly beats connecting two things together with a cable.
__________________
Main gear: Mac Mini > HRT Streamer II+ > Marantz PM66 KI > Mission 794
Also cluttering-up the place:
Thorens TD160 no cartridge; Marantz CD63 mkII KI; Technics SL-P777; Cyrus 2 + PSX; Cyrus Tuner; Nakamichi DR-1
hammill
hammill's picture
Thanks, I already have homeplugs which do indeed work well. My tablet, phone and son's ipod all require wireless.
hammill
hammill's picture
Thanks, but that is a bit big - I may want to deploy on the landing, so one of the plugin ones is probably more suitable. I notice on Amazon that there is a TP-LINK TL-WA850RE which fits the bill.
MajorFubar
Ah fair do's...just thought I'd mention it in case you'd never heard of them. I hadn't heard of them 'til quite recently, nor have most of the people I know.
__________________
relocated
relocated's picture
Will an Apple Airport Express do the job?  Link it to your router and it creates another wifi zone as well as other things.  Not very cheap I suppose but I'm sure I have read that it is a solution.
__________________
Apple Lossless - ATV3 - AVI ADM 40  or  Marantz CD50SE (modded] - AVI ADM 40
also ATV3 into AVI ADM 9T [my wife's system] and Grado SR80i
chebby
chebby's picture
Online
Apple Airport Extreme 802.11n base station.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
Feral
Feral's picture
Useful utility for checking if neighbours or other devices are hammering a particular wireless band.  Enables you to choose a quiet band and potentially improve performance although you may have checked this already.
http://www.metageek.net/products/inssider/
Feral
hammill
hammill's picture
Feral
I have already changed channel, but thanks for the suggestion. It is a long way from my wireless router to the back of the house.
