Brik Audio Hifi - Bluetooth Receiver
1 reply [Last post]
El Hefe
El Hefe's picture
I just purchased a Brik Audio Bluetooth receiver and a Power Master PSU.
Its basically provide the same function as the QED uPlay but physically just much more sturdy and provide an upgrade path to its PSU.
Will provide a review soon.
__________________
HiFi: ClearAudio Concept TT, Musical Fidelity M6i and M6 DAC, M1s (CDT, CLiC, ViNL), Onkyo TA2600, SONY MDSJA20ES MDP, ProAc D18 with full Siltech cabling.
HT: Samsung UA55B7000 LED, OPPO BDP 95-EU,Marantz DV4003, Yamaha RX-V2067, Philips DVDR7300H, Infinity Primus Center, Wharfedale WH2, SW15 Sub, Mission M34i with full QED cabling
Bedroom: BRIK Audio BT Stage, Bose WAVE Music Sytem III
HeadFi: Alessandro Grado MS Pro, Bryston BHA-1 headphone Amp.
Office: iTunes, UD100 USB DAC, Bose Companion II, Musical Fidelity HPA headphone amp, Bose Over The Ear
El Hefe
El Hefe's picture
RE: Wi-fi
Built
BT receiver – nothing to shout about. Light but nicely designed and ‘looks’ expensive. Power supply not the best quality. Running on 12V DC.
Power Master – Heavy duty. Heavy by weight in comparison with the size. The off/on button could be more sturdy. Sometimes it does not lock in when push to on.
Connectivity
Connected to my iPhone and iPad within few seconds. No fuss. Any sounds from the iPhone and ipad can be streamed to this unit. Even the sound of email coming in !!!. However, tried running a Radio App and it gave a loud buzzing sound. So be warned, make sure to lower down the volume before changing things on your iPad or iPhone. No signal drop out throughout 3 hrs usage. Yes, I was up till 3 am this morning. J
Set up
Connected directly to M6i amp using QED Signature IC. Playlist on my iPad for AB comparison as follows. All either in MP3 320kbps/48kHz file or Apple Lossless
1. Andrea Bocelli + Sarah Brightman – Time To Say Goodbye
2. Metallica – Enter Sandman
3. Foo Fighters – My Hero
A-B comparison done with the following:
1. iPad connected wirelessly to Brik BT Stage with QED Signature IC to M6i
2. iPhone4 in Wadia 170i dock feeding MF X DAC via coaxial with QED Signature IC to M6i
3. iPhone3GS connected to QED uPlay with QED supplied IC to M6i
4. iTunes on iMac connected wirelessly via Airport Express to M6i
I didn’t compare it to CD replay as the idea is just to test the level of SQ satisfaction VS convenience gained.
The Listening Session
1. The Brik BT Stage came out a bit harsh in the beginning with very muddled presentation. Didn’t like it. High notes by Sarah Brightman and Solianos sounded too harsh to my ears. The unit also somehow boost the bass level up a notch. I think that’s why it sounded muddled. Not very impressed. It got worst when I put on multi instrument music. Too messy.
2. Two thumbs up with the volume level though. Listening at 9 o’clock on the M6i knob, no difference in volume level between 1, 2 and 4. QED uPlay was the worst. To get the similar volume level, had to crank the knob on M6i to 12 o’clock.
3. Set up 2 above still gave the best SQ to my ears. Taking the digital files from iPhone4 and let the MF X-DAC do the processing produce very sweet sounding music.
4. Connectivity however was no issues on the Brik BT Stage. No signal dropout although sometimes changing between songs, I can hear ‘click’ sound. The worst connectivity was Airport Express as it was over my WiFi which is not that strong in my hifi room. So signal drops out once in a while.
5. Convenience – having the BT Stage is definitely a plus. No need to walk down to the rack and change music on the iPhone. Eventhough the Wadia has a remote, but you still cant choose your song.
6. However, after about 2 hrs of playing music on BT Stage, the sound seems different. Maybe because I was already sleepy J. I went to bed feeling a bit disappointed.
7. This morning, had a go again. Aaaaaahhh now the BT Stage sounds different. Not to say better but different. It still sounded a bit muddled but it starts to give out the character of the music. Multi instrument music sounds more airy than last night. Maybe its just a placebo effect.
Verdict
Can I call this BRIK a hifi piece that can satisfy my needs after 12 hrs of purchase? Yes for convenience, 50-50 for SQ.
Will it continue to sit together with the rest of my hifi kit? Will decide this weekend.
NOTE: Why did I buy it? The original power supply for my QED uPlay went kaput. And no warranty on the plug. Replacement cost 30 quid. End up using a 2 quid AC/DC power supply bought from hardware store.
Why did I buy the Power Master? Same case with BRIK items like BT Stage, DAC and Phono Stage. Power supply ie plug not covered by warranty
__________________
