Bluetooth Audio Streaming from PC to Home Theather System
Hi everyone! Can any1 help me stream my audio content via bluetooth from my pc to my home theather system? I have a Samsung HT-X710T. I can stream audio from my sony ericsson mobile via bluetooth but not from my pc using a usb doogle. The pc found my system and its already paired up with it.
My mistake ... I meant i have a bluetooth usb doogle. Im trying to stream music from my pc (using Itunes) going to my home entertainment system. I was hoping there would be an option in the preferences windows to select my audio output but i couldn't find any option. Someone mentioned usig Windows Media Encoder to 'broadcast' my music to my home entertainment system but im not quite familiar in using it.
This may be of interest to you, you can downlaod a trial version to see if it works, iTunes version 6.0.2 and higher is supported. It might only support A2DP headphones although you might be able pair your dongle with your Samsung as a Bluetooth stereo headset using this software.
Link - http://www.bluesoleil.com/life/index.asp?topic=bsmusic
Dante_hunter:My mistake ... I meant i have a bluetooth usb doogle.
Is the dongle you've chosen A2DP capable?
The dongle is a physical device that holds your music files. However, the device that holds your music on your pc is software (I would imagine), like WMP, Itunes etc.,. You will need to check the settings on the software that you use. Obviously I am guessing here as you haven't given much detail.
Screen - Samsung UE46D8000. Sources - Dell Zino HD 410; Sky HD; Sony BDP S550; Wyred 4 Sound DAC1. Amps - Yamaha RX-A3010; SimAudio Moon I-3 RS. Speakers - Vienna Acoustics Mozart Grand; Vienna Acoustics Waltz Grand centre; Proficient Audio W690 rears; Monitor Audio RSW12. Cables - Van Damme Blue 4mm speaker cable; Townsend DCT300 and Atlas Voyager interconnects; Van den Hul Optocoupler.
