Anyone had experience of HomePlug AV Adapters?
10 replies [Last post]
Peter Bleakley
Peter Bleakley's picture
Interested to know if these plug network adapters cause interference to the electrical supply for my Hi Fi or TV. They seem like a good idea but I'm not sure.
Anyone had any experience?
VoodooDoctor
VoodooDoctor's picture
Re: Anyone had experience of HomePlug AV Adapters?
I use them to network my house. I haven't noticed any effect on my TV or hifi.
__________________
MA PL200s, PL350C, PLW-15, PL100s
 Onkyo PR-SC5509 -> Leema Acoustics Pyxis, Hydra II (x2) & I
JRiver 18 Leema Acoustics Elements DAC Panasonic BDT-310 PS3 X360 Wii Virgin Tivo
 Samsung PS64D8000
Andrew Everard
Andrew Everard's picture
My experience is that they made the sound of my system somewhat flatter and less involving - they didn't last long...
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
j6jno
j6jno's picture
Andrew,
Can you elaborate on your setup, I use these plugs to connect my Media centre to my network and stream music from my NAS to the Media centre which then passes it through a coaxial cable to the amp to playback.
I havent notice any difference in performance or playback using the plugs or a direct 'hard' wired connection to the router.
Andrew Everard
At the time I was using Naim DVD 5/TAG McLaren Audio amps/PMC speakers. Haven't tried such devices recently, as I was so put off at the time.
__________________
j6jno
j6jno's picture
I use mine on the ring main and then use a separate mains plug socket to feed an extension lead with power surge protection and I have not noticed any issues, perhaps I should invest in a decent extension power lead and try again ????  Any recommendations anyone ???
Andrew Everard
If you don't notice any issues, why change anything?
__________________
j6jno
j6jno's picture
Fair point, but its always good to have something to tinker with. Keeps me out of trouble !!!
JamesBernal
JamesBernal's picture
I use the Devolo powerline products to connect my home server to my router which is then connected to my Squeezebox. Work perfectly and have never had any reliability issues with them. I don't have an ultra-expensive set-up but I don't really see why these should impact your overall sound quality. Compared to all of the other electronic devives in your home the impact of these transmitting data through the ring-main should be fairly negligable.
I'd highly recommend them compared to the alternatives of a) Wiring you whole house with ethernet cables or b) Using wireless connections for AV streaming which would be more likely to cause sound issues due to drop-outs etc.
rogueelement
rogueelement's picture
I use a Belkin powerline adapter for the PS3 as the wireless connection was not up to snuff for online gaming or even downloading hefty updates.
For the record....the PS3 itself (and all other AV kit for that matter) are powered through a mains conditioner.
The vast improvement over wireless made it worthwhile and I see no degradation of picture or sound quality from the PS3 as a result of having a powerline ethernet connection.
__________________
PJPro
PJPro's picture
I used to use power plug network adapters and found them to be good. I don't use them now cos I have a dedicated gigbit network. I didn't notice any issues with them.
__________________
My useful(?) What HiFi Forum threads can be found here.
