Airport Express
5 replies [Last post]
Booster
Booster's picture
I've just bought an Apple TV, but will it work with my Airport Express wireless network? I'm worried that it might be too slow to stream video content from my Mac to the TV.
Genyus
Genyus's picture
Re: Airport Express
Although the best performance will be had with an (ideally pure) 802.11n network, you should be able to get by on your existing Airport Express, depending on the sort of video content you're intending to stream. See this article for some useful insights into using Apple TV with an 802.11g network: http://www.macworld.com/weblogs/macword/2007/04/tvweek/index.php
haider
haider's picture
Re: Airport Express
 It's really simple, get a BardUSB system from Sonneteer. Plugs and plays and there is absolutely no delay. It doesn't stream it broadcasts and it's design for high end audio. Win win. S_ y_u won _ave _ny gli__ng _obl_ms.
__________________
Haider
sonneteer.co.uk
Genyus
Genyus's picture
Re: Airport Express
I don't believe the BartUSB will solve the OP's problem - he wants to stream video across his home network; as you yourself pointed out, the BartUSB device only broadcasts audio.
haider
haider's picture
Re: Airport Express
Yes well absolutely the case. As the two can work together to solve any prblems with data rates etc. The BardUSB has less than 1ms latency and hence will work with the video in real time. Also allowing the video more bandwidth on its own. Or have I misjudged this? Is the audio suddenly too fast? On the MAC, if i am not mistaken, you can select teh audio device you wish to use. You then simply chose the USB device and presto.
Anyway its an idea.
__________________
Haider
sonneteer.co.uk
Genyus
Genyus's picture
Re: Airport Express
I don't quite follow you. Network performance aside, the Bard Rx system only transmits audio data and only has audio connections, so how do you propose to supply a video signal to display on the receiving TV?
