Aftermarket Antennas
I was wondering if the aftermarket antennas for wireless network cards actually give improved performance? Anyone got any experience and recommendations? I found these on eBay but not sure if they are any good:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120306690072
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=110294306071
I have three PCs with Netgear WPN311 network cards.
Many thanks!
Great. I wonder if they work as well when fitted to the wireless network cards. My Netgear DG834PN router has internal antennas and you can't connect an external one. I also find this but its alot more expensive:
http://www.amazon.co.uk/Hawking-Hi-Gain%C2%BF-Indoor-Antenna-HAI15SC/dp/B0000DIET2/ref=sr_1_14?ie=UTF8&s=electronics&qid=1228171337&sr=8-14
It got some good reviews on Amazon in the States:
http://www.amazon.com/Hawking-HiGain-Directional-Corner-Antenna/dp/B0000DIET2/ref=sr_1_1?ie=UTF8&s=electronics&qid=1228177322&sr=8-1
By the way how long is that one you bought from eBay?
Cheers!
dont see why it would't work attached to the network card i think that's what they're intended for tbh. but i had the opposite scenario to you... my laptop has an internal antenna and the router an external one
btw it has an overall length of 8 inches
well i bought the one in your second link to replace the one on my router ,as when i was using my laptop in my bedroom which is a loft conversion (and the router is on the ground floor) i used to get really weak signal and drop outs but since changing it no drop outs and signal is upto 4 bars
have to say i was dubious as to whether they'd make any difference, but at that price i took a punt and was pleasently surprised
