Advice on streaming please
4 replies [Last post]
geordie777
geordie777's picture
Hi I would appreciate some advice please.
I have a PC upstairs and I want to improve the sound I get from it so I thought maybe a Dacmagic linked up to some speakers I already have would do the trick but
A.  Would I need a new amp or would a Dacmagic Plus do the job.
B. if I wanted to stream the music downstairs to my hifi ie. using something like Airport Express would I need another Dac to play the music through my old technics system.
__________________
Rega RP1 Golding 2100 Cart. Marantz pm6004. Marantz cd6004. MA BX2s
John Duncan
John Duncan's picture
RE: Advice on streaming please
A.  Depends what the amp is - can you tell us what you've got?
B.  You wouldn't *need* a DAC as the AEX has an audio out, it's just a bit average.  Adding a DAC would improve the sound, but it might not be worth it depending on the quality of the Technics system.
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
geordie777
Sorry do not have an amp upstairs just the pc so would I need an amp as well. Thought Dacmagic plus had integrated amp.
Also technic system is 20 years old so no USB for the airport express anyway.
__________________
John Duncan
No it has a built in headphone amp but it wouldn't power speakers. For that you'd be better looking at something like an Onkyo tx-8050.
As for the airport express, it has a headphone socket-style audio out so would plug in to the Technic fine; I wouldn't worry about an external DAC for it in the first instance.
__________________
geordie777
Thanks that's a great help.
__________________
