Advice on new Wireless Router
15 replies [Last post]
D.J.KRIME
D.J.KRIME's picture
I currently have a Belkin Wireless G+ router(phone line not cable) and frankly think it is quite rubbish especially as it cost £70. I am on my 3rd unit due to break downs now this one keeps loosing internet conection unless my main computer is turned on, which has a wired conection to the router (adsl light is still ok so there is actually a conection avalible)
Now Belkin blame my ISP and my ISP blame the routerAngry
I also have issues with this router where both My Xbox 360 and PS3 say that the NAT on the router is too strict.
Any recomendations???
__________________
My usefull posts Laughing How To Calibrate Your TV
heystak
heystak's picture
Re: Advice on new Wireless Router
I use BT Homehub which is excellent in terms of reliability and signal.
Also no chance of an ISP / router supplier conflict.
However, BT may not suit you if you have a phone line / broadband contract with ANOther.
margetti
margetti's picture
D.J.KRIME:
That old chestnut! Is your ISP saying the router is faulty, or not 'compatible' with their network?
First thing you could try is a factory reset on the router - I've found this often works when nothing else has. If you really have had enough of the Belkin though, I've found Netgear (in recent years) to be pretty reliable (others will probably have different experiences though!).
Regarding NAT for the 360 and PS3, do you have uPnP enabled on both the router and the consoles?ÿ
ÿ
__________________
Sonneteer amp, cdp & phono amp, Systemdek IIx900, Onkyo 876, Ruark spkrs + REL sub, bits and bobs
Gerrardasnails
Gerrardasnails's picture
D.J.KRIME:
Netgear! I use the DG834GT router that came with my Sky broadband and it's brilliant - never had a problem.
__________________
Screen - Samsung UE46D8000.  Sources - Dell Zino HD 410; Sky HD; Sony BDP S550; Wyred 4 Sound DAC1.  Amps - Yamaha RX-A3010; SimAudio Moon I-3 RS.  Speakers - Vienna Acoustics Mozart Grand; Vienna Acoustics Waltz Grand centre; Proficient Audio W690 rears; Monitor Audio RSW12.  Cables - Van Damme Blue 4mm speaker cable; Townsend DCT300 and Atlas Voyager interconnects; Van den Hul Optocoupler.
Ravey Gravey Davy
Ravey Gravey Davy's picture
I concur with the Netgear crew.Had them for several years at home and in the office and they are brill. The new range max are supposed to be outstanding if a little more expensive (£100+)-here
blackcabmal
blackcabmal's picture
I have a netgear router which was supplied with sky broadband a couple of years ago i guess and i am always having to re-boot the thing and often i,m told i,m not connected to the internet as i write all the icons on the router are flashing like mad,does it sound as iÿcouldÿbe in need of an upgrade.
sorry D.J Krime i did not mean to sabotage your thread.
Murrayÿ
John Duncan
John Duncan's picture
I have a Belkin which, once I got it working (ISP had to allow MAC address), hasn't let me down (or at least not any more than you'd expect from a wireless network). I suspect there's nothing wrong with it and you just need to sort out the config...
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
D.J.KRIME
D.J.KRIME's picture
So if i went for say the expensive Netgear max would this give me a very good signal all around my house as I sometimes find my 360 strugles to conect to my current router due to weak signal even tho the G+ is ment to have a very wide range. Also is the netgear still going to give me the NAT issues I am getting on the games consoles as when I was using a BT router I never got these issues.
__________________
Ravey Gravey Davy
D.J.KRIME:
I can't promise you on the NAT issue,but the blurb says it is good for internet gaming, and my son is constantly on  360 live gaming through the same model router as Gerrard, using netgear mains bridges rather than wireless and hasn't complained yet (except for the constant freezing of all his games but that is more likely impending RROD) .
I am going to see if I can borrow a Rangemax from my friendly IT mate and try it out cos I have signal strength issues.
D.J.KRIME
D.J.KRIME's picture
Forgive me for acting dumb but what are "mains bridges" that you mention?
__________________
margetti
margetti's picture
D.J.KRIME:
Difficult to say as I'm not overly familiar with the Belkin or the latest Netgear stuff. Tried to see if the specifications for either included some indication of coverage, but couldn't find much that was useful. Coverage will depend on distance and building structure, often with unpredictable results.
Best bet I think would be to buy from a retailer that will happily take the item back if it doesn't do the job (and allowing a good week or two to test over time). Would have thought that shouldn't be a problem for most retailers?
Can't say if NAT issues will disappear as it can't be said for certain at this point that the Belkin is at fault. We had problems with the PS3 network when on Tiscali, but never with any other ISP (using the same router). So ISP's can be at fault too. Again, best bet will be to try another router and evaluate from there...
ÿ
__________________
Ravey Gravey Davy
D.J.KRIME:
See Here  - plug one into the router and the nearest mains socket and the other into the xbox and nearest mains socket.Another form of hardwiring.
John Duncan
Ravey Gravey Davy:
D.J.KRIME:
Oh dear. Oh dear oh dear oh dear...nasty things. Nasty nasty.
__________________
D.J.KRIME
D.J.KRIME's picture
I take it you dont rate these JD?
__________________
Ravey Gravey Davy
JohnDuncan:
Ravey Gravey Davy:
D.J.KRIME:
Well ,put it this way, I've used them for data transfer  ,the kids for gaming and music and we do not have issues.
Now then,
Can opener - check
Wormbait- check
Fire  -from the Naim   topnotch HDX CD ripper web page
Network Streaming
As well as a stand-alone hard disk music player, the HDX is a music server that can provide up to six different streams of music simultaneously over a home network. Install an HDX and you've installed the heart of a multi-room audio system too. You don't even need to install copious reels of new network wire either as network hardware that uses existing household mains cables can do the job.
Ravey Gravey Davy
DJ - the last post was not meant to hi-jack- I'll report back once/if I get the opportunity to borrow the Rangemax.
JD - I am not taking sides on the bridge issue but it is an interesting take on viewpoints.
