Accessing wireless LAN from Android phone?
3 replies [Last post]
Petherick
Petherick's picture
Hi
Please forgive me and point me in the direction if this is covered somewhere else..
Can I access my wireless network from my HTC Desire? I would like to be able to access shared files on it. It's already set up to use the network to connect to the internet, but I can't figure it out.
Thanks in advance.
__________________
Trousertrumpet
Trousertrumpet's picture
RE: Accessing wireless LAN from Android phone?
Petherick wrote:
Hi
Thanks in advance.
Yes.
There are many apps for it. I use ES File Explorer. I couldn't say if that's the best as it's all I've bothered using other than Teamviewer... Teamviewer will let you access your PC desktop remotely.
__________________
All that glitters is not gold.
Petherick
Petherick's picture
Thanks, I've just installed it and will give it a try.
__________________
Petherick
Petherick's picture
Thanks Trousertrumpet, ES File Explorer works really well!
__________________
