Which 46-50" TV should I buy?
I think I've narrowed it down to the following 4 models... can anyone advise which is best or perhaps suggest an alternative if I've missed one? I'm looking for something that is as future-proof as possible:
LG 47LM960V
Samsung 46ES8000
Samsung 46D7000
Sony KDL 46HX853
Many thanks
Panasonic TXPGT50, What Hi-Fi's current 50-inch best buy.
thanks - not a huge fan of panasonic but budget is up to 2k although would prefer to be sensible about it i.e. if I can find something on offer for say 1k that's only marginally inferior to a current top of the range model then I'd rather do that.
Panasonic this year is really good.
Not sure why you're not a Panasonic fan, as the quality of TVs they're producing is nothing short of outstanding, & the 50GT50 is available for half the price of your budget with a free blu ray player & 3D glasses, & is better than the TVs in your shortlist in my opinion.:
http://www.whathifi.com/forum/hot-deals/the-best-tv-for-£999
Amongst your list, Sony HX853 is the best LED lit LCD TV I ever saw. I didn't like the Samsung ES8000 as the colour saturation and motion handling wasn't as good as the Sony.
+1 for the Panasonic or the Sony.
As you can see in my signature i have the Sony.
If i were after a slightly bigger TV i would be looking at the Panasonic too without a doubt, i compared both when purchasing mine & at the end of the day the Sony only won because it was the right size for me with the room available. When i went for the demo i found the picture quality on both TV sets outstanding fed with HD content. The Samsungs you mention when i viewed them seemed to have a lot of motion issues.
Regards..
Thanks guys, that's really useful and I'll take another look at the Panasonic. Does anyone own or has demo'd the LG? Would be keen to get some feedback on that one...
- Login to post comments
LG 47LM960V
Samsung 46ES8000
Samsung 46D7000
Sony KDL 46HX853
Many thanks
Musical fidelity M6i Roksan caspian M2 cdp Atc scm 40s Tellurium Q black speaker cable chord chamelian xlr graham slee novo sennheiser hd598
