32 posts / 0 new
Last post
nugget2014's picture
Last seen: 1 day 2 hours ago
Where can i buy sony KDL46W905??
really wanting to buy this TV. but richer sounds dont have it in the Nottingham branch.
Where can i get this tv for around the same price as richer sounds if anywhere??
if i can't get the sony 905a. will the newer sony kdl50w829 have as near good picture quality as last years flagship?
its either the 829 or the 2013 805a if i cant get the 905. which one is better? the 805 would be 55" for £900
Setup: Samsung UE55JS8500, Samsung UBD-K8500 4K Player, Dali Zensor 3, Dali Vokal Centre, Denon AVR-X2200W, Arendal Sub 1, Monitor Audio Radius 45, Elac Debut Atmos
gel
gel's picture
Online
Last seen: 52 min 23 sec ago
RE: Where can i buy sony KDL46W905??
I'd go for the 829 first.   Smile
Stop
simonlewis's picture
Last seen: 5 days 53 min ago
gel
gel's picture
Online
simonlewis wrote:
John Lewis
Yep.
Stop
would you say the 829 is on the same level as the w905 in terms of picture quality?
i read that is has triluminos like the w905. but i cant see that it does on sony website. does it have such good colours as last years flagship w905?
so here are my options:
1) get the sony kld50w829 tv for £899 with a free sony BDPS-6200 blu ray player and 1 in 5 chance to win a  PS4.
2) get the sony kld46w905a for £799.95 (buy my own blu ray player , sony bdps-5200 £100) and no chance to win a ps4
is it worth the extra money to get the 2013 w905 which has triluminos technology for better colours etc? all i want is the best picture quality i can get. do not care for sound as i am using home cinema
bigboss's picture
Online
Last seen: 1 day 17 hours ago
I think you should demo both TVs and buy what looks best. W905 has triluminos, but also suffers from narrower viewing angles.
gel
gel's picture
Online
Yep, I agree.
Colours tend to be stronger on the flagship ones, but then you are getting the extra size with the one down from this year.  It's hard to tell without a direct comparison.
Stop
john lewis is the only place who has both tvs in stock. do the tvs have option for 3d to be turned on so i can see what its like? i dont wanna buy an active tv for the first time if i cant see it. would help if they had both tvs side by side but thats probably out the question in JL
bigboss's picture
Online
Check it at John Lewis. They may have kept them side by side.
gel
gel's picture
Online
I did a comparison today in the Sony shop and I couldn't see a difference, both were really good.  Both had strong colours and were nice.
Stop
what was the source material, i'm sure on a blu ray disc or something the w905 might have better colours? because of triluminos
also. i assume a £1600-1700 tv brand new last year which the w905 was should be far better than this years 829 which is new at £899..? if its basically 90% the same..im confused
gel
gel's picture
Online
This years 829 is reviewing far better than last years 8 series did.  It was on the same demo material, it was high definition though.
Just the same being shown on every TV, other than the 4K one. Prices are a bit misleading because this years has dropped a little. I would take your own Blu-rays with you when you demo, because today was hard to pick them apart.
Stop
john lewis let you put blu rays in to demo? :o
still leaning in favour of the w905.
gel
gel's picture
Online
Yep.
I own Two Sony TVs too, the Sony 46hx803 and the Sony 40lx903, so I know what the difference between those two are too.  It is pretty similar along the lines you are thinking now.  The 903 has stronger colours but the 803 benefits from size.  Both are good TVs so, you are definitely going to do well out of it.
Stop
Pages
Log in to post comments
