8 posts / 0 new
Last post
alpne1's picture
Last seen: 3 years 2 months ago
Vertical lines
Hi I have a Samsung 51" plasma TV in the living room that has developed three pink/white lines top to bottom in the same place on the TV. I thought it might be Sky but after disconecting it and playing a DVD the lines are still there. TV is less than a year old bought from Currys. Any ideas. Thanks in advance
chebby's picture
Last seen: 1 day 3 hours ago
RE: Vertical lines
There you go. Under warranty.
(Well, you're not going to put up with those lines are you?)
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
alpne1's picture
RE: Vertical lines
Do you think it is a definite fault with the TV ?
Son_of_SJ's picture
Last seen: 5 months 5 days ago
RE: Vertical lines
Yes.
Parlour: Sony KDL-75W855C and 12.1 system; Kitchen: Panasonic TX-P65VT65 and 8.1 system; Front bedroom: LG 60PZ950T and 5.2 system; My bedroom: Pioneer LX5090 and 7.2 system. Retired, since Sat 13-Feb-2016, Pioneer 428XD!
Alantiggger's picture
Last seen: 1 month 1 week ago
RE: Vertical lines
Like the Great man sang.... ' return to sender'     Smile
Alantiggger
alpne1's picture
RE: Vertical lines
:wall: :wall:  Checked the warranty |(  out by one month.
chebby's picture
RE: Vertical lines
You only had a one year warranty on a 50" Plasma ?  That's odd.
Anyway, still ask for them to deal with the fault. Also email (& phone) the manufacturer.
The_Lhc's picture
Last seen: 3 months 1 week ago
RE: Vertical lines
Yes, you're well within your statutory rights to have the issue dealt with, 13 months for (presumably) quite expensive plasma TV isn't a reasonable or acceptable lifespan.
Log in to post comments
