31 posts / 0 new
Last post
Alec's picture
Last seen: 1 day 8 hours ago
Unwatchable telly
No, this isn't some kind of Eldorado retrospective; my telly has been suffering increasing levels of "interference" to the point where it is almost not worth bothering with.
I've tried to find some pictures of the kind of thing I'm getting but to no avail. There are big lines across the screen, that predominantly green thing is happening toward the bottom and of the screen sometimes, and it goes blank now and then, just for good measure.
So what should I be troubleshooting?
simonlewis's picture
Last seen: 1 day 6 hours ago
RE: Unwatchable telly
Get the aerial checked out if that is fine treat yourself to a nice new telly, from what you mention with green lines i'm guessing a new telly.
abacus's picture
Last seen: 7 hours 58 min ago
If it’s only on the input then change the cable, if it affects the whole TV (Including Tuner and other inputs) then there is nothing you can do but get the repair guy in. (It’s unlikely to be user fixable)
Hope this helps
Bill
Alec's picture
Thankyou both. I'll report back when I've investigated all that.
BenLaw's picture
Last seen: 1 year 11 months ago
Is it in warranty?
I am the danger.
Alec's picture
Yes, it came with a free Pana warranty, if I registered it...
I'm getting sound drop-outs on the radio through the freesat but that's not what you mean, or is it?
daveh75's picture
Last seen: 6 days 21 hours ago
Is this with all sources or just Freesat?
Sounds like the picture blocking/freezing/green screening and sound drops/pops you get from signal/reception issues
Alec's picture
No pops as yet, but I've had the rest. I've only been using the freesat. Should it even have problems with a disc if its the telly?
Alec's picture
The Dark Knight Rises is playing OK, and recorded programmes play OK, as long a they were recorded before the problem started.
chebby's picture
Last seen: 7 hours 50 min ago
So are you watching/recording via the Freesat tuner in your Humax or the Freesat tuner in your telly?
If via Humax - swap external coax (from dish) to Panasonic - bypassing the tuner in the Humax -  and see if problem persists.
If via telly      -  swap external coax (from dish)  to Humax - bypassing the tuner in the telly -  etc.
This will isolate which tuner is playing up (if a tuner is the problem).
If problem is still there - whatever tuner is used - then it's dish/cables. (It would be a colossal coincidence if both tuners were knackered at the same time.)
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
Alec's picture
Thanks Chebby. I always watch Freesat via the Humax.
chebby's picture
With a co-ax 'fly lead' into the back of the Panasonic?
If so, put the Humax into standby (not powered off) and the tuner duties will be picked up by the Panasonic's tuner automatically. You will know this has occurred because you'll see the Panasonic EPG rather than the Humax EPG.
If the Humax and TV are only connected by an HDMI lead,  then just take out  the co-ax lead from the back of the Humax and pop it into the Freesat co-ax input on the telly.
I have both co-ax fly lead and HDMI connections between TV and Humax so I can get digital audio from the Humax passed through to the TV (and then to my hi-fi with an optical connection from the TV).
Alec's picture
Well, I noticed the orange-y "surround" light was going off on the soundbar every time there was a problem with the picture, but now it's got to the stage where, when I put something on, all I get is a few seconds of sound, then nothing. No picture at all.
I need to get someone to give me a hand trouble-shooting; hopefully I'll have doen that before the weekend's out.
EDIT - even with older recordings I'm getting the "channel is scrambled..." alert (which I usually associate with weather - rain in th edish or something...) and nothing more.
Dougal1331's picture
Last seen: 1 year 9 months ago
Have you enquired about getting it replaced?
It shouldn't matter that you haven't 'registered' as long as you have the original reciept- if it is still in the warranty period, it is not 'fit for purpose' whether  registered or not, surely?
EDIT or is it the box that's dying? Too early in the day for me...
Alec's picture
Not sure which, if either, is dying yet Dougal.
Its nearly OK today, so maybe there's something in the dish or something...?
BenLaw's picture
Have you done what Chebby suggested yet?
I am the danger.
Pages
Log in to post comments
