4 posts / 0 new
Last post
daveyjay's picture
Last seen: 6 months 1 week ago
Sony KDL-50W829 programme guide
The programme guide on the aformentioned set doesn't show all the information for all the channels. Indeed, most of the time it only shows beebs 1 and 2, everything else says no information available. No such problem with the Samsung 6400, which shows all programme info for all channels all of the time. Why the difference? Both tvs are using the same aerial etc.
simonlewis's picture
Last seen: 4 days 12 hours ago
RE: Sony KDL-50W829 programme guide
First of all disconnect the aerial set your tv to tune in for stations, -it won't find any obviously then reconnect your tv aerial and perform a re-scan again and hopefully your problem should be sorted.
daveyjay's picture
I'll give it a go, simonlewis. Thanks for the reply. I'll let you know how it goes...
daveyjay's picture
Yep, I think that's done the trick, simonlewis. Many thanks.
Log in to post comments
