2 posts / 0 new
Last post
wolf7howl's picture
Last seen: 2 years 6 months ago
Set up options
I have a range of HDMI sockets on my TV and AV amp.  Has anyone compared PQ/SQ connecting sources directly to the TV with connecting via an AV amplifier?  What are the advantages / disadvantages of each set up?
Currently I have the blu ray player and the V HD box connected to the TV via HDMI with coax and optical audio connections respectively to the AV amp, The TV also has an ARC HDMI link to the amp. Is it worth connecting all my sources to the amp via HDMI and outputting from the amp to the TV?
I am getting a replacement panel, so I will be fiddling with cabling anyway.
Panasonic TX55AS802B, Sony STR-DN1040, Sony BDP-S6200, V HD box, Dali 1 5.1, Audioquest FLX SLiP speaker cable, Audioquest Pearl HDMI, Atlas Element Integra subwoofer cable, Cambridge optical and coax digital interconnects
Glacialpath's picture
Last seen: 6 months 1 day ago
Re: Set Up Options
Hi there how are you?
Personally if you have and AV receiver and lots of source components it's best to us the AVR as your main hub. That way you should get a more relyable  sync with audio and picture.
There shouldn't really be any difference in Pic or sound quality. You won't need the TV remote apart from turning it on if you leave it on standby.
Also you only need 2 cables then. Just the HDMI ones.
Hi-Fi: Campridge audio D500 SE, DACMagic 1, C500, P500.. Monitor Audio BR1 speakers.
H-T: Pioneer; Kuro LX5090, BDP LX71, SC LX73. CA P500. SKY+HD. Rel Q50. Mordaunt Short Avant.
Log in to post comments
