Samsung UE55ES8000 function Sound
I’ve just bought the above and use a sound bar but then you adjust anything, change channels, go into the menus etc it makes the most deafening bleep to confirm the change, I can’t find a menu to adjust this sound can anyone help as my ears are starting to bleed!!!!
Hi!
There is in fact an entry in the menu for adjusting the "beep" but I'm travelling at the moment and won't be back until next week, by which time you will probably have worked it out!
I can't recall the exact sequence in my head but it is there
Hi Simon,
The issue isn't with the soundbar, that works perfectly, I have the TV sound turned down to 0 and moderate the volume using the soundbar but the function bleep volume is independent of TV volume, so it comes through the soundbar at a level Ted Nugent would be proud of.
Still, which soundbar is it?
I bought the Yamaha 401
I'm afraid i can't help haggy, but it may help other members to help you by telling us the make & model no. of your sound bar, have you tried searching online.
formerly known as slewis ---
simon's system
