27 posts / 0 new
Last post
OldboyVsNinja's picture
Last seen: 1 year 5 months ago
Samsung UE48H6400 Best settings
can i please have the best settings for this Samsung UE48H6400 telly please from either a what hifi reviewer or forum member please thanks :?
simonlewis's picture
Last seen: 1 week 1 day ago
RE: Samsung UE48H6400 Best settings
thanks but dont have any spare money :oops: budget went on tell and bluray player just want basic steps 2 improve motion and pic quality spelt wrong i think
bigboss's picture
Last seen: 1 week 2 days ago
http://www.avforums.com/pages/pictureperfect/
thank you very much
daveyjay's picture
Last seen: 4 months 1 day ago
On the upside, I'm sure it won't take you long to get a cracking picture, OldboyVsNinja. On the downside, however, good luck with the lip syncing.
bigboss's picture
You haven't asked if his set has problems with lip syncing.
daveyjay's picture
I just assumed it has got lip sync problems after my experience with said tele. But, you are quite right, Gel, I should ask. So, have you noticed any lip sync problems with off air tv, OldbyVsNinja?
Gel hasn't commented on this thread ???
no lip sync problems but my set wont download updates so i have 2 download 2 usb and do it that way cant be bothered 2 return the set because of that
daveyjay's picture
No lip sync problems? That's interesting. I don't want to state the obvious, but, we are talking off air, here, aren't we, OldboyVsNinja, not via Bluray or anything? And, you aren't running the sound through a home cinema set up? Because, if you haven't got lip sync problems, I'm definitely taking my set back to the shop.
mine is fine apart from not downloading updates but i can live with that got 5 year garantee from richer sounds so if it bothers me ill just replace it if yours is unbareble just replace it?
daveyjay's picture
Got mine from Richer Sounds, also. I'm trying to ascertain whether or not I've got a faulty set before I go to the trouble of reboxing the beast and taking it on a long journey back to the shop. If my set is faulty, I'm fine with making the aformentioned journey, of course. I suppose the only way to find out is to look at another set. I would be absolutely over the moon, if it turned out to be a fault, because I'm so pleased with all other aspects of the tv - As mentioned in my other posts, I agree fully with the WHF five star verdict - the picture is just amazing, for the money - I imagine you'd have to part with a fair bit more cash to better it.
bigboss's picture
Why haven't you spoken to Richer Sounds yet about the lip sync issue? Just ring them and speak to them.
daveyjay's picture
Yeh, I've spoken to Richer Sounds a couple of times, bigboss - just didn't think it was worth reporting. I'm getting a replacement next week - hoping I've just been unlucky the first time. Keep you posted...
kevin939's picture
Last seen: 2 years 6 months ago
I just bought one of these and it is a really great TV - super picture, surpringly good sound
Thought I had got a really great deal from Pixmania - BUT I was wrong. The TV is an import and does not do DVB-T2
The website has a couple of litle notes that give it away.......a lesson learnt READ THE SMALL PRINT
DAMN
Pages
Log in to post comments
