5 posts / 0 new
Last post
near dark's picture
Last seen: 3 months 1 week ago
Samsung & 4OD app
For some reason only adverts will play via 4OD on my TV. Shows just produce the spinning buffering circle. 4OD on my other devices work fine.
I tried to un-install 4OD,but could not select the app. Others were ?
4OD was installed when purchased . Apart from restoring the TV to presets,is there another was to un-install 4OD ,then re-install ?
Thank you
Paul.'s picture
Last seen: 12 hours 35 min ago
What model is your TV?  I
What model is your TV?  I believe if you highlight an app then press the Tools button, there is an option to delete or reload the app.  There is also an option to reset the smart hub, but off the top of my head I can't remeber where.  Will have a look later.
near dark's picture
Paul. wrote:
Hi Paul.
Sorry,my model # is UE46F6500SBXXU.
I tried the tools button,but the apps that were pre-installed like 4OD can not be un-installed ,unless Im doing something wrong?
I remember seeing an option to re-set the smart hub,was am unsure what this involves
Thank you
Paul.'s picture
Unfortunately my TV is an E
Unfortunately my TV is an E series, so I'm not too familar with yours.  The reset smart hub option should factory reset just the hub, not touching other funtions on the TV.
One thing I have noticed, there is usualy a newer version of the firmware available to download manualy than there is through auto update. Try here, see if this version is newer than your TV firmware.
http://www.samsung.com/uk/support/model/UE46F6500SBXXU
near dark's picture
I have reset the smart hub,still the same. The firmware is already updated to the latest version
Log in to post comments
