5 posts / 0 new
Last post
raulty's picture
Last seen: 3 years 3 months ago
replacement projector
Hi evryone
I had A LG AF 115 projector & i know at the time was one hell of a projector .but due to water damage it has become to expensive to repair, so looking for something that will fit the bill
Any recommendations would be great
thanks
Matt :roll:
themovierooms's picture
Last seen: 1 year 8 months ago
RE: replacement projector
Hi Matt,
What is your budget, screen size & throw distance?
raulty's picture
Thanks for the reply
screen will be 100" diagonal 16.9.throw is 2 -2.5 metres budget is 1500-2000
thanks
Matt
Two options I would recommend at your price point.
The first one is the Epson EH-TW8100, superb picture and all-round performance for the money, 3D & very bright for normal viewing. Second one would be Sony's VPL-HW30es, last year’s model and won’t be around for much longer but you can pick one in your price range brand new with the 3 year Sony warranty.
For me the Sony edges it on performance but for 3D has an external emitter which can be tricky to place within the room.
RWhite_25's picture
Last seen: 3 years 7 months ago
I'd rather suggest you to consider SANYO projectors too. They've also got unbiased reviews and much inexpensive than others. Many projector hire dealers used to keep SANYO stuff as a reliable product for rental services due to thier longevity. Have a look at this: http://www.avdj.co.nz/projectors-screens/data-video-projectors, the service provider has kept SANYO projectors for all kind of hire services and this makes a lot of sense.
Log in to post comments
