4 posts / 0 new
Last post
johnrambo's picture
Last seen: 2 years 5 months ago
Projectors, TV's & Viewing distances
My room is a really awkard shape  12 x 4 metres with a fireplace bang in the middle of the 12 metre wall and a huge window spanning the opposite wall so it only really leaves a place to put a tv or projector against the 4m wall.
Originally I had thought about putting a 55" tv against the 4 metre wall (around  7 metres away from the viewing position) but im not sure it would be big enough for reading text (it would for 50% of the time be plugged into a pc for web browsing  and some gaming)
Long story short im wondering if a projector is the way forward. If I had a 120" screen and a projector situated around 4-5 metres away would that be suitable to cast the image that large? Id be looking at a VPL-HW40ES
Thoughts and suggestion appreciated
kikiso's picture
Last seen: 4 days 8 hours ago
Yes, depending on the
Yes, depending on the projector. There is a really handy calculator at http://www.projectorcentral.com/projection-calculator-pro.cfm which allows you to pick a projector and see what image size etc you can get at any given distance. I have just checked against my projector which is an Optoma HD25 and at 4.5 metres you can get 120 inches.
Denon AVR-X4300H,
Arcam P25 (3 channel),
Rega P25/Nagaoka MP200/Heed phono pre-smp
Spkrs: B&W CM8 Front Speakers. Dynamic Audio, SVS SB1000
Sky Q Silver (hate it)
bigboss's picture
Online
Last seen: 21 hours 7 min ago
At that viewing distance, a
At that viewing distance, a projector is, without a doubt, the way forward. Sony HW40 is a brilliant option; I'm considering that myself.
Will you be able to maintain good darkness? If not, look at Draper ReAct 2.1 screen.
KieraMcLean's picture
Last seen: 2 years 3 months ago
TV and Projector Installation
In case of TV and projectors, the angle from your place to the device should be 70 to 60 degrees angle at a best distance of 7 feet.
Log in to post comments
