24 posts / 0 new
Last post
rhamilto's picture
Last seen: 1 year 2 months ago
Plasma Screen Damage SOS
I have a Hitachi 42PD7500 42" plasma screen TV (okay, okay, it's a bit outdated now, and while connectivity and general design/build are aged, the picture quality remains decent for HD, and the sound of the standard supplied speakers remain the best standard speaker quality I have heard yet - in terms of 'size', depth, surround, punch, fullness).
Anyway.  yesterday disaster struck.
Cleaned the screen with a standard window/glass cleaner spray (as has been done countless times before without any issues whatsoever) - and there appears to have been some sort of caustic reaction with the cleaning product.
The outcome is that a very thin top layer of the screen seems to have been corroded off - almost as if the solution was too acidic.
When the television is switched off, the damage looks awful.  Viewing is not ruined.
It was a major supermarket chain's own brand.  I won't name them yet.
A call to their Customer Services department was dealt with, with surprising sympathy.
They invited that the product be dropped off at the Customer Services desk of my local store - and they will end it off for analysis.  This, I have been advised, will take around 2 weeks.
Perhaps of significance is that they gave a refund on the cleaning product (remember their own brand stuff).
So - my questions to which I invite debate:
1) has anyone on here ever heard or experienced this before?
2) does anyone have any advice that may help guide me through this most unwanted occurrence?
3) are there any similar war stories?
All responses gratefully read with interest.
Thanks.
RobH
bigboss's picture
Last seen: 6 days 8 hours ago
RE: Plasma Screen Damage SOS
As far as I'm aware, plasma manufacturers advocate NOT to use any cleaning solution on the screen.
Andrew Everard's picture
Last seen: 3 years 5 months ago
Specifically, the Hitachi TV's manual says:
'Clean the screen with a soft cloth moistened with warm water and dry with a
soft cloth. A mild soap may be used if the screen is extremely dirty.
Do not use harsh or abrasive cleaners!'
So while the formulation of the cleaner you're using may have changed, assuming you've been using the same one all along, you may be on dodgy ground as you really shouldn't have been using the cleaner in the first place. Or it could just be that cumulative applications of the cleaner over time have been eating away at the coating on the screen to the point where eventually something major appeared to happen.
It'll be the screen coating, not the glass itself, that's damaged, and while it might be possible to have the screen recoated, or even a new panel put in (if spares are still available, which is unlikely, given the age of the set), it would probably not be economically viable to do so on a TV now knocking on eight years old.
strapped for cash's picture
Last seen: 4 months 2 weeks ago
You can perhaps take this as a sign that it's time for a new TV.
Unfortunately, it sounds like you've stripped away part of the anti-reflective coating. Once done, this can't be repaired without replacing the screen. This would be expensive (perhaps impossible, as it's an older TV).
Sorry, that's not what you want to hear, but it's unwise to use abrasive cleaning products on a plasma screen.
EDIT: I'm basically repeating everything Andrew said. At least there's consensus on your issue.
rhamilto's picture
All,
Thanks for replies (thus far).
Of particular interest to me is that the product itself does NOT provide any messaging warning NOT to use on the screen (glass) of televisions.
This may clearly be a current gap in product messaging.
They refunded on the product; which to me, at least, could be interpreted as an acknowledgement of culpability perhaps.
Oldboy's picture
Last seen: 1 week 4 days ago
I've yet to find a manufacturer that recommends you use anything other than a soft damp cloth with which to clean ANY screen, my current Sony HX853 LED tv manual has a very clear warning to not use anything else than a damp cloth to clean the screen. In order to shift stubborn finger marks you can use some very diluted washing up liquid in a bowl of water and use the cloth with this but I would never use a cleaner of the like you describe on my tv screen.
The problem is that most tvs these days have some sort of coating on them to aid with reflections and picture quality so the issue is not just limited to plasma screens, as harsh as it sounds you really should have read the manual with regards to how you clean the screen and in this case i'm very sorry to say that you are responsible for the damage to the tv screen and not the manufacturer of the cleaning product in question.
It's time for a new tv, to get 8 years out of the Hitachi is good going as it's lasted well. Sorry it's not good news but I would say you are responsible for not following the advice set out in the manual.
LG OLED55C6V TV, Marantz SR7011, Dali Zensor 5 7.1 (front presence configuration), Sony BDPS790, Marantz PM6004, Marantz CD6003, Virgin TiVo 1TB, Playstation 4 Pro, WD TV Live, WD My Book World 1TB.
The_Lhc's picture
Last seen: 3 months 1 week ago
It probably doesn't tell you to use it to clean your contact lenses before putting them back in your eyes either but...
Every flat screen manual I've ever seen states very clearly not to use any kind of cleaner on the screen, you've obviously never bothered reading yours.
The fault it yours, nobody else's, sorry.
bigboss's picture
Andrew's message indicates that Hitachi's TV manual does indeed state that. I don't think a refund is an admission of culpability. They're merely following their policy of refund if you're not happy with the product.
Alantiggger's picture
Last seen: 1 month 1 week ago
Page 2 of the user manual  states    :read:
"CAUTION
To prevent scratches or damages to the plasma screen, do not
knock or rub the surface with sharp or hard objects. Clean the
Do not use harsh or abrasive cleaners!"
Argh.
Alantiggger
relocated's picture
Last seen: 1 year 10 months ago
I am afraid that, whilst it may be a bit of a harsh delivery, the LHC is absolutely correct.  It is long overdue that people take responsibility for their own actions.  How many things must be listed on a product, because there will never be enough?  Someone somewhere will find an inappropriate use for things.
Even if you were in the right, are you going to have the product independantly tested?  No I didn't think so.  So you will never know if it is out of spec because they aren't going to cough to it.
Expensive, but useful life lesson.
Apple lossless - Netgear Nighthawk - ATV3 - AVI ADM 40.
AVI ADM 9T used in my wife's system
rhamilto's picture
Thanks for replies.
My point in this is NOT that I would look to Hitachi for a refund.
It would be more that a consumer product that is intended for "windows and glass", and that doesn't contain any warnings against use on television screens, is what has seemingly caused damage to a personal item of mine.
I am merely pointing out that a product sold, without any caveats or warnings, for cleaning glass has damaged something.
If this is a known by-product of the cleaning product - then it should be clearly labelled with a warning (in my opinion).
If it is hitherto NOT a known by-product of the cleaning product - then this event will alert them to it.
What happens next is interesting.
Thanks for the feedback though.
bigboss's picture
But then there's a massive difference between glass and TV screen. A TV screen isn't merely glass. It has a special coating on it which can easily get damaged. In my 4 years of plasma TV ownership, I've never even wiped the screen with a dry cloth / duster, leave alone using a cleaning solution.
professorhat's picture
Sorry, I don't think you'll get a lot of support on this one. You're putting the emphasis on the cleaning product to list things it shouldn't be used on that look like glass. I suspect if legislation came in to insist on this, such cleaning products would need to be sold in a box to allow for the inclusion of a leaflet (that no one would read incidentally) to include all the possible glass like constructions available in the world that shouldn't have the cleaning product applied to them (just in case).
Meanwhile, you've got the TV manual which did state not to use your cleaning product on it. If you'd read it, you wouldn't even be talking about the above requirement. Time to hold up your hands and take some responsibility I'm afraid, rather than trying to shift the blame on to someone who is genuinely blameless in this instance.
The owls are not what they seem...
Cofnchtr's picture
Last seen: 8 months 1 week ago
I'm with the majority on this.
The TV manual clearly states what NOT to use but you go ahead and use it anyway and it seems not for the first time...nobody to blame but yourself.
See it as divine intervention and purchase a new TV.
Cheers,
Cofnchtr.
proffski's picture
Last seen: 8 months 2 weeks ago
"CAUTION
Argh.
Emphasis on 'soapy' most detergents even the good ones contain salt, not good for the screens!
BIGBERNARDBRESSLAW's picture
Last seen: 8 months 6 days ago
I bought a belt sander today, and I can't find anything in the manual about not removing light scratches from the bezel on my tv with it, so do you think it'll be ok? >)
Panasonic TX-P50GT50 / Yamaha RX-A2020 / Panasonic DMP-BDT110 / Dali Zensor 3 / Dali Zensor Vokal / Mordaunt Short MS20i Pearl Edition / Cambridge Audio Minx 11 / Tannoy TS2.10 / Roksan Radius 5.2 / Ortofon Super OM 20
Pages
Log in to post comments
