7 posts / 0 new
Last post
RobinKidderminster's picture
Last seen: 3 months 3 weeks ago
Plasma Image Retention
An obvious tip or useless idea?? Suffering only briefly once, I occasionally give my screen a 5minute 'wash'. Tune into analogue with no input (unplug the aerial?) and enjoy the black & white snow. Entrancing as well as useful ?
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
bigboss's picture
Last seen: 1 week 2 days ago
RE: Plasma Image Retention
You're doing all the right things. Smile
Which Panasonic model have you got? Have you got Pixel Orbiter (I think that's what it's called)?
Pixel orbiter??? Its a TV not a bloomin' space rocket! Smile
No. Its a Pana P42G20. BBC breakfast was the culprit a while back but cleared easily after a wash.
bigboss's picture
Smile
Your Panasonic should have the pixel orbiter in menu options, which is specifically designed to remove IR. Run it every now & then.
rocketrazor's picture
Last seen: 1 month 1 week ago
I just checked my g20 as I thought it had pixel orbiter, and it doesn't. I can't find it anywhere in any of the menus. My gt50 does though, although its off for THX mode
I cant find it BB but since I dont have an issue I wont worry. Hopwfully other non pixel orbiterians may use my suggested wash to some enefit tho.
gel
gel's picture
Last seen: 4 days 15 hours ago
I avoid all the news channels which my TV does not seem to like.  I avoid any channels with logos that are big and colourful or try not to leave it on them for very long.  The pixel orbitor is on and when I did get some slight retention the TV healed itself!
Stop
Log in to post comments
