plasma for £1500
Fri, Jul 27 2007, 9:09PM
I know with my budget I can get a very good tv. Yet I dont know what plasma to go for?
can you suggest a few so I can compare them etc
can you also suggest what DVDs are good to take to demos? as I want to test the set ups Im after.
cheers
PIONEER PDP4280XD 42" HD Ready Digital Plasma TV from www.dixons.co.uk Selling at £1,595.00 but if you put in 100JULYAW in the promotion code box, you should be able to get another £100.00 off.
Also see www.hdtvtest.co.uk for a very indepth Technical review
