11 posts / 0 new
Last post
Sospri's picture
Last seen: 1 year 10 months ago
New TV option
Hi Guys,
               My old Panasonic 32inch is showing signs of age, so its time for a new one.
My criteria is quite simple really, size would be around 40" LED, with a budget not exceeding £700.
I'm not interested in 3D my feed is freeview usually from my Humax freeview recorder which gives me HD.
I have BBC iplayer ect with the humax.
I saw this at a good price, Samsung ue42550, would this suit my needs or are there any others that would be better ie Panasonic ect.
Thanks in advance for your help in this as the choice is so huge.....................
gel
gel's picture
Last seen: 6 days 12 hours ago
RE: New TV option
Sospri wrote:
Hi Guys,
This plasma is a great deal:
http://www.johnlewis.com/panasonic-viera-tx-p42gt50b-plasma-hd-1080p-3d-smart-tv-42-inch-with-freesat-freeview-hd/p231568176
Stop
laserman16's picture
Last seen: 1 month 3 days ago
RE: New TV option
But the OP wants a LED TV.
Sospri's picture
RE: New TV option
I have seen the samsung at £528 which seems like a good deal, any comments on this set would be welcome....................
simonlewis's picture
Last seen: 1 week 4 days ago
RE: New TV option
I couldn't find the tv you mentioned how about this samsung you should be able to find it less than £700 & in budget.
BIGBERNARDBRESSLAW's picture
Last seen: 7 months 2 hours ago
RE: New TV option
Do you mean this?
http://www.appliancesdirect.co.uk/p/ue42f5500akxxu/samsung-ue42f5500akxxu-42-inch-smart-led-tv?refsource=APfroogle&gclid=CIX_j7TC7bYCFZMbtAodthEA0g
I can't find any reviews of this tv, and I'm not familiar with this supplier. Crampton & Moore have it for £549, and they're a respected supplier, so it might be better to pay that little extra to get from them.
The tv though, will be something of a punt, as there is a distinct shortage of reviews for this model. My guess is, it will be decent, but you'll probably have minor problems with backlight bleed, and motion. I'm guessing though.
Panasonic TX-P50GT50 / Yamaha RX-A2020 / Panasonic DMP-BDT110 / Dali Zensor 3 / Dali Zensor Vokal / Mordaunt Short MS20i Pearl Edition / Cambridge Audio Minx 11 / Tannoy TS2.10 / Roksan Radius 5.2 / Ortofon Super OM 20
RE: New TV option
If you bought it at Richer Sounds, you'll get a free 5 year warranty, from a highly respected supplier.
That's got to be worth the extra money for peace of mind.
http://www.richersounds.com/product/tv---all/samsung/ue42f5500/sams-ue42f5500
bigboss's picture
Last seen: 2 days 1 hour ago
RE: New TV option
BIGBERNARDBRESSLAW wrote:
Do you mean this?
Appliances Direct is same as Direct TVs. They're reliable, & have a shop in Huddersfield. I've bought few laptops from them (Laptops Direct) since 2005. They're good to deal with.
bigboss's picture
RE: New TV option
Richer Sounds should price match Appliances Direct / Direct TVs.
gel
gel's picture
RE: New TV option
This TV is like 5 times better though.  Smile
Stop
Sospri's picture
RE: New TV option
Yes Sorry Simon that is the model I meant.......................
Log in to post comments
