New TV Bought...now need help!
Hi All,
Just bought a Samsung UE46C8705 (C8000 in UK???) for what I think was an OK price at £1000 (10000sek) but I am a little unsure of how best to set it up.
I've read the quick tips on the site and on my old TV I did the THX disc calibration thing but then I've been told that you shouldn't use a DVD if you're setting up the TV to use mainly bluray, is this the case? If so is there any tests you can buy or download that you can use instead to get it right? Maybe something throught the USB?
Anyway, first impressions are pretty awesome, was a little hesitant as I was late to the shop and ended up taking the one on display but it didn't even have a fingerprint on it let alone a scratch...éven managed to get some extra specs thrown in for good measure.
Thanks as always...
Franklioni
