7 posts / 0 new
Last post
Nyorker's picture
Last seen: 3 years 8 months ago
Need plasma advice: Panasonic or Samsung
Hi all,
I'm looking to finally replace my HD ready telly, and I'm having a tough time trying to decide between the Panasonic UT60 and the Samsung 60D550 (I chose these two because they're within my budget). Smart features are less of a concern, and they're more or less the same price.
Any recommendations?
GSB
GSB's picture
Last seen: 7 months 3 weeks ago
RE: Need plasma advice: Panasonic or Samsung
Which do ypu prefere?
Nyorker's picture
I'm kind of in a bind...wanted to know if anyone out here had experience with any of these.
Paul.'s picture
Last seen: 2 days 10 hours ago
The problem is, the D series Samsungs are two generations old, can you still buy them?  The UT60 is not a model in the UK, did you mean UT50 or ST60 perhaps?  Are you based elsewhere?
What is your budget, maybe someone can make a suggestion?
Nyorker's picture
I live outside the UK, and outside the higher-class models (65ST, etc.), these are themodels that fit my budget - roughly 1,500 pounds.
Both are 3D, 1080p models. The Panasonic model doesn't include glasses while the Samsung does plus an extra HDMI (3 vs 2 on the Panny).
Obviously the Samsung has more advanced "smart" capabilities, plus built-in wi-fi, unlike the Panny where you need an extra dongle.
Paul.'s picture
I will guess from your forum name that you are US based, I would consider this if it is in budget:
http://www.amazon.com/Samsung-PN60E6500-60-Inch-1080p-Plasma/dp/B0077T0TUS
$1488, I have the 51" version and its a great TV, the 60" supposedly has better black level performance than the 51".
Son_of_SJ's picture
Last seen: 2 weeks 4 days ago
And a review of the 60-inch British version is here http://www.trustedreviews.com/samsung-ps60e6500_TV_review_3d-and-verdict_Page-1
My nieghbour two floors above me in my block of flats, on my recommendation, bought this very 60-inchSamsung television from Currys for about £1,600 about four months ago, and he seems quite happy with it!
Parlour: Sony KDL-75W855C and 12.1 system; Kitchen: Panasonic TX-P65VT65 and 8.1 system; Front bedroom: LG 60PZ950T and 5.2 system; My bedroom: Pioneer LX5090 and 7.2 system. Retired, since Sat 13-Feb-2016, Pioneer 428XD!
Log in to post comments
