5 posts / 0 new
Last post
admin's picture
Last seen: 2 days 16 hours ago
LG 50LA660V-ZA
Hi just would like to know the best settings for hd viewing on my lg 50LA660V-ZA,so many settings on it and not sure which to have on and what best settings would please to the best picture quality?
simonlewis's picture
Last seen: 6 days 10 hours ago
RE: LG 50LA660V-ZA
swuk37's picture
Last seen: 2 years 8 months ago
RE: LG 50LA660V-ZA
Hmm not cheap and not for novices
robjcooper's picture
Last seen: 4 weeks 11 hours ago
RE: LG 50LA660V-ZA
the spears and muncil disc 2nd edition has been designed to be used by novices with full step by step guides.
However, if that's still too expensive, you could try using the THX optimiser set up which you'll find on a selection of blu rays. However, to make the most of that, you'll need a pair of blue filter glasses - you can get them from THX in the states
http://www.costore.com/THX/productthumbnails.asp.
Or you could risk one of the 'genuine' selection available on fleabay
First thing you should do though is make sure you've turned all the pointless processing off.
good luck
Rob
the full list of movies including the THX Optimiser are here
http://www.thx.com/consumer/home-entertainment/thx-certified-releases/?type=releases&pg=2
swuk37's picture
RE: LG 50LA660V-ZA
can you list what ones are pointless processing
Log in to post comments
