led 3d tv for £500
24 replies [Last post]
triflesterms's picture
any suggestions?
ideally want 40'
please help
simonlewis's picture
Online
RE: led 3d tv for £500
Plenty of choice, look here.
__________________
formerly known as slewis ---
simon's system
thanks for the link, i've had a look through the tvs and couldnt find any that are rated by what hifi.not sure where else to look?
Online
The samsung UE40F6100 gets good reviews on amazon, i don't think you will find better than that for £500 with 3D.
__________________
simon's system
Hi Simon
thanks for the reccomendation, this tv looks ok though i want smart tv as well.
I dont mind paying a bit more if i have to, but i'm on a tight budget.
Paul.'s picture
Do you have to buy right now?  You will struggle with your budget right now if you want smart and 3D, but if you can wait untill after Christmas you will find bargains Smile
__________________
Paul's system thread
(where the photos live) Paul's Flickr page
Hi Paul,
Thanks for responding, i'm without a tv at the moment so it would have to be now unfortunatly.
As i said i dont mind spending a bit more if i have to, though i'm having a hard time to find anything anything that has 5 stars in what hifi.
Paul.'s picture
__________________
Alantiggger's picture
__________________
Lounge :  Samsung PS51E6500, Sony BDP S790, Virgin media XL with HD Sports Channels (BT &Sky),  Yamaha RX-V673.
Tannoy Arena 5.1 with stands.(http://www.techradar.com/reviews/audio-visual/hi-fi-and-audio/hi-fi-and-av-speakers/tannoy-arena-96472/review)
Bedroom: Panasonic PX70 TV and a Sony BDP-370 Blu ray Player & Kitsound Boomdock.  (quite superb for sound)
So far  :)
Thanks for your reccomendations guys
I've had a look at both TV's and they both seem quite good, i'm not sure which one would have the best picture out of the two.
I couldnt find many reviews for the samsung LED.
Negative points for LED ->
  • Potential clouding
  • Narrow viewing angles
  • Glossy screen causes reflections  -----  Slightly concerened about the clouding issue, not sure how regular this could be?
Negative points for Plasma ->Slightly sluggish Smart menus at timesPictures not as bright as LCD ones - not sure how much brightness would be lostStandard definition images lose a little colour naturalism  ---- Slightly concerned about how much difference this would make?I would also be wanting this tv for gaming so not sure how much of a difference that makes?I know that both TV's have a motion rate of 600 Mhz.So i guess now i'm not sure which one to go for out of the two or if there are any other options out there that i should consider?Cheers
Potential clouding
proffski's picture
LCD TV LED BACKLIT.
Did you mean an LCD TV which is backlit by LEDs?
Sorry i forgot to mention that i would be wanting to hang the tv on the wall and have just read that there are issues with the hanging the plasma, as the Tv's rear sticks out a bit.
I'm not to bothered if it sticks out a bit as long as that i can still hang it on the wall.
Yes, sorry my mistake.
I've just bee reading that the above plasma isnt to suited to day time viewing, most of my viewing would be on the night though i would still like the option to watch in daytime.
How bad is this tv for day time viewing?
Can you still see the picture?
bigboss's picture
Online
Plasma is absolutely fine for daytime viewing, unless you're keeping the TV in direct sunlight. Personally, I prefer plasmas for their natural rendition of colours and inherently better motion control without any artificial processing.
__________________
Paul.'s picture
The 51F5500 has no anti reflective coating what so ever.  it has the same pannel as my Tv (51E6500 from last year) except my TV has a pretty good coating (Real Black Pro according to the marketing fluff) And even with this coating I have to pull the curtains a bit in day time.
__________________
