5 posts / 0 new
Last post
Aqua's picture
Last seen: 10 months 2 weeks ago
leaving a plasma in the box ?
hi
really need a expert opinion on this hope its not a silly question
i have recently moved back into parents house and saving for a house but last month brought a 60" plasma tv
and the idea was to keep it as it is in the box for when i move back out..how long this will be i dont no.
brought it as its now discontinued and wanted this particular model.
so question is; will it be ok to keep as it is for a long period of time in the box for when i go or would i be better off using it ??
simonlewis's picture
Last seen: 1 week 3 days ago
AFAIK it should be okay as
AFAIK it should be okay as long as you keep it upright.
bigboss's picture
Last seen: 1 day 4 hours ago
Make sure you check it for
Make sure you check it for any manufacturing defects though.
Aqua's picture
do you mean turn it on and
do you mean turn it on and check it all or just turned off ?
bigboss's picture
Turn it on & check.
Turn it on & check.
Log in to post comments
