17 posts / 0 new
Last post
simonali's picture
Last seen: 1 week 4 days ago
Lazy boy sound improvements
I've recently bought a 2013 Panasonic ET60 TV for the lounge and the sound is dreadful. It requires external speakers in my opinion, but what I want to know is whether this is possible without resorting to a second remote for adjusting the volume? If I were to connect a compatible soundbar to the HDMI (ARC) input does the TV then know it has external speakers and not to use the weedy internal jobbies??
bigboss's picture
Last seen: 1 week 3 days ago
RE: Lazy boy sound improvements
Yes it is possible. You won't need a 2nd remote.
simonali's picture
Cheers for that, bigboss. I'd been reading up on ARC/CEC, but it was all rather confusing because the manufacturers are free to implement it in different ways, rather than it being a defined standard. I'm guessing my best bet is to stick with Panasonic gear just to make sure?
simonali's picture
Well I went in a local TV store today just to audition a few different soundbars. Listened to a couple of the Panasonic ones and was left unimpressed. Ended up walking out with a Sonos one that I couldn't afford!
Don't tell the missus how much they cost...  :shhh:
bigboss's picture
What's your budget for the speakers? You can always get a cheap universal remote to control everything.
Yamaha makes the best soundbars.
Also check this:
http://www.qacoustics.co.uk/qacoustics-qtvx-speakers.htm
simonali's picture
As stated I already bought a Sonos Playbar. Budget was about half what it cost!
bigboss's picture
Oh, you meant the Playbar. It is very good! Have you got anymore Sonos gear?
bigboss's picture
I hope you're going to use the Playbar for multiroom music as well. If for pure TV speakers, it is a waste of money.
simonali's picture
No, I haven't. Made the set up a bit of a pain, as I had to rob some networking bits off the home cinema to get it going! Still sounds a bit weedy with the TV sound, but that must be how they broadcast it. Movies are a diffent story, though, the sound is excellent and it plays music really well, too.
bigboss's picture
Remember it can directly play music from your PC / iPad / NAS drive wirelessly. You'll need to connect the Playbar via ethernet cable to your router, or connect Sonos Bridge to your router, & the Playbar will wirelessly connect to it.
http://www.sonos.com/shop/products/bridge?lang=en-us®ion=uk
bigboss's picture
Playbar review here:
http://www.whathifi.com/review/playbar
simonali's picture
It is networked now, as the only way to get it to work is with the app, there's no remote for it in the box. It goes through a set up procedure and then learns the volume control signals from your TV remote near the end. You then disable the TV speakers using the hotel menu. I just need to do the PC now so I can play music from there on it...
bigboss's picture
Enjoy your Playbar!  :cheers:
simonali's picture
Will do. I am gonna get a Bridge once the bank cards stop smoking so I can get rid of some of the wiring behind the TV. It doesn't work wirelessly until you have another bit of Sonos kit in the network which seems to be a clever way of getting some more dosh out of you...
bigboss's picture
Basically, the requirement of Sonos is that at least 1 unit should be hard wired to the router. It then creates its own mesh network.
simonali's picture
Indeed. As that is the case I shall spend as little as poss buying the Bridge and connect that to the router. Then I can reconnect my AV amp using the bits I've borrowed.
Pages
Log in to post comments
