5 posts / 0 new
Last post
admin's picture
Last seen: 19 hours 29 min ago
Humming noise
I've just bought a new Toshiba 37c3030 37"LCD TV and am very pleased with it. Sound is good and picture quality is excellent from both broadcast and from DVD's played through my Sony DVD player. But when playing a DVD there's a light humming sound when the scene is bright (no humming during dark scenes). This is my first LCD flat panel TV so I'm a bit of a novice. Any ideas what might be causing this? I have the DVD player connected with a scart lead.
Andrew Everard's picture
Last seen: 3 years 4 months ago
Re: Humming noise
 Backlight noise? Could be - check on in the shop where you bought it and see whether that one does the same thing. Must admit hadn't noticed Toshibas as particularly noisy in this respect
Anonymous's picture
Re: Humming noise
Thanks for your reply Andrew. I bought it online from Dixons (got a great price), but I didn't notice this humming sound on any Toshibas I viewed in a shop. I tried adjusting the backlight setting down to zero but it didn't make any difference to the noise.
As I mentioned previously, it only hums when playing a DVD and only in light scenes. When watching normal TV there is no humming at all, so could it be something to do with the DVD player or how it's connected to the TV?
Re: Humming noise
 Somehow I doubt it - it would be very unusual. Could be something to do with what the internal scaler is doing - that's the only way i could imagine it would depend on the brightness of the image.
Anonymous's picture
Re: Humming noise
Problem solved! It was a faulty scart lead. Used a new scart lead and no more humming... you could hear a pin drop now.
Log in to post comments
