Hi i got a big problem! Can`t get pictures or sound from my receiver from my new 3D Tv
12 replies [Last post]
Heat87
Heat87's picture
Hi peoples
Got a big problem! Can`t get pictures or sound from my receiver (Pioneer sc-lx72) with my Samsung UE46ES8000.
Can someone please help me?
Many Thanks
Best Regards
nads
nads's picture
so how have you wired it
so how have you wired it up?
have you read the manual?
why do you think you can get sound from the TV out of the amp?
__________________
Not a HiFi Nut. Just has a pile of Nads.
Heat87
Heat87's picture
Hi Nads
Hi Nads
I have plug everything on receiver ps3, blu ray + pc and then i use (HDMI OUT) to HDMI  on my old led tv, then i got picture and sound.
And when i plug into my new Samsung led 3d smart tv i get nothing.
nads
nads's picture
so how have you conected it?
so how have you conected it? what is sending the TV sound to the AV?
and the rest of the kit is connected to the AV by what?
__________________
Oldboy
Oldboy's picture
RE: Hi i got a big problem!
Sounds like ARC to me. If you got sound from connecting your last tv by using a HDMI cable only then it would point to you perhaps not using the correct HDMI socket on the tv as normally only one is ARC enabled and you need to connect to this type of HDMI socket to get sound and pictures from the tv.
Check your connections on the tv as on my old Panasonic GT30 the ARC HDMI was on HDMI 2 and not 1, it may even be the case that there is a setting within the menu to activate it but that's unlikely, however as i don't own the tv i couldn't say for certain.
I presume that when you connected your last tv to the amp you didn't use an optical cable or standard RCA leads to get sound from the tv to the amp??
__________________
Sony KDL46HX853, Yamaha RX-A2020, Dali Zensor 5 5.1, Panasonic DMP-BDT500MR, WD TV Live, Marantz CD6003, Marantz PM6004, Beresford TC-7220 MKII, PS3, Xbox 360, QED Silver Anniversary XT speaker cable, Wireworld Chroma 7 HDMIs, Chord Crimson Sub and RCA, Chord Superscreen Mains Cable
The_Lhc
The_Lhc's picture
Does the LX-SC72 support ARC?
__________________
No signature worth mentioning...
Oldboy
Oldboy's picture
Good point, i presumed it did from what the OP said about his previous connection with the old tv....perhaps not??
__________________
The_Lhc
The_Lhc's picture
I'm not entirely convinced he's talking about getting sound from the TV to the amp at all, I think he's saying when he plugs everything into his new TV he doesn't get audio or video from ANYTHING. I might be wrong of course (it has happened...) but until he comes back and clarifies matters we'll never know.
__________________
BenLaw
BenLaw's picture
Probably just need to go into the HDMI settings on the TV and enable the HDMI port you're using.
__________________
HiFi   /   A/V   /   Bedroom
Oldboy
Oldboy's picture
That may well be the case as it's not entirely clear what the issue is from the OPs original post, hopefully he clears up what the issue actually is soon but from the way I read it I thought the issue was with sound from the tv to the amp but of course I may well be wrong about that and got it completely wrong (not for the first time) Smile
__________________
Heat87
Heat87's picture
Hi peoples thanks for the answers
Hi peoples
Thank you for your reply, i think its the Arc problem i have plugged the amp Hdmi out to Hdmi 2 <-- Arc
Nothing happens, wont find signal or sound.
The Anynet find my receiver but wont show up in source mode.
I dont have optical cable, didnt used that on my old tv.
Pioneer LX-SC72 doesnt support ARC or dont have 1.4 (3D) hdmi.
But all i know the new receivers 1.4 (3D) have Arc hdmi out something like that,
What i did on my previous tv, with my amp.
I plugged ps3,blu ray and pc on HDMI 1-2-3
1 cable to HDMI out to TV-HDMI, and there i got picture + sound.
Pluss i fixed something on my pc, that my amp is the main sound for my pc.
So all i want is, everything comes from my amp picture and sound through receiver to Tv.
nads
nads's picture
RE: Hi peoples thanks for the answers
Heat87 wrote:
Hi peoples
so you are saying your old TV had an HDMI out?  well your new TV does not. and your AMP does not have ARC so you need more wires. what depends on what there is on the TV and if it will pass sound from the source you want or you need to do what most people do and that is connect your kit to the AMP first and then an HDMI to the TV.
__________________
The_Lhc
The_Lhc's picture
Heat87 wrote:
Pioneer LX-SC72 doesnt support ARC...
I'm still not clear on what you're trying to achieve? If you know the amp doesn't support ARC then don't use the ARC HDMI on your TV, use HDMI 1 instead.
I might be imagining it but I seem to recall some people mentioning that some TVs require the HDMI ports to be individually enabled (ie the ports are switched off by default), sounds daft to me, I don't recall doing that on my TV but that might also be something to look at.
__________________
