Help with annoying Pop Up
4 replies [Last post]
PhillH1975
PhillH1975's picture
Hi Guys
I have just managed to bag the last in the shop of the Panasonic TXP42GT30 on a very good deal. As the TV had been set up in the shop i didn't need to go through all the set up details from scratch. However i have a problem, every 30 mins or so the features of this tv pop up on screen, easy to get rid of, but after a few days now it is starting to get annoying.
I have been through all the menu but for the life of me cannot see were i can turn this off. Can anyone help me please?
The TV by the way is brilliant
John Duncan
John Duncan's picture
RE: Help with annoying Pop Up
What do you mean by 'the features'?
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
The_Lhc
The_Lhc's picture
Online
Sounds like an in-store demo mode. Ring the shop and tell them you want someone to come over and turn it off as they should have done that before they boxed it up.
__________________
No signature worth mentioning...
Paul.
Paul.'s picture
Are you referring to the demo mode?  Hold down the volume down button on the set, and the menu button on the remote for 5-10 seconds.  It will do a full factory reset and show you a self diagnostic screen.  Switch the tv on and off again, and you should be good to go.
__________________
Paul's BR/805 system thread
(where the photos live) Paul's Flickr page
PhillH1975
Yes it looks like the in stored demo mode, thanks for the advice.
