Connecting a VCR - advice required
12 replies [Last post]
Cass
Cass's picture
I’ve just set up my mother-in-law’s new LG LCD TV, and found it has only one SCART, which has so far prevented me from connecting her VCR to the TV. Currently, her Virgin V+ box is in the HDMI 1 socket and her DVD player in the single SCART. I tried daisy-chaining the DVD player via the VCR’s SCART but it didn’t work – the TV failed to detect a signal from either the DVD or the VCR that way. So, any suggestion as to the best way to connect the VCR? The options seem to be: (1) Buy a SCART splitter/switcher – but do these work reliably? (2) Attempt to connect using an RCA composite cable. The VCR does not have a video RCA socket on the back – only the L & R sound sockets – but it does have all three on the front, so I assume I could use those? Any thoughts on the best approach?
__________________
Marantz CD6002 / Logitech Squeezebox Touch / NAD C326BEE / Mordaunt-Short Avant MS 902i / Chord Carnival Silverscreen
professorhat
professorhat's picture
RE: Connecting a VCR - advice required
Either approach should work fine. Probably the splitter is the easiest and best option - I used many a splitter in my time and all worked fine. You can get ones which auto-detect signal, or some which come with a remote to switch between the two sources.
One note on the RCA connection though - the RCA socket on the front is probably an input not an output (this is fairly typical to allow connection of a camcorder). However, you should be able to get a SCART to RCA converter which will plug into the VCR's scart socket on the back like this:
I assume the TV has all three inputs (i.e. yellow, red and white connectors)? As the yellow connection only carries video so you'll need the red and white to carry the sound.
MajorFubar
MajorFubar's picture
No, the ones on the front of the VCR will be inputs, not outputs.
If the TV has a composite input, the best idea would be to use that via a SCART to composte adaptor, like the Prof has shown. Though make sure you buy an adaptor with a switch which can be changed between 'in' and 'out' (you want 'out' of course). You could also buy a SCART-to-phono cable instead, but the cheaper ones are only single direction so you have to be careful which ones you buy.
__________________
Main gear: Mac Mini > HRT Streamer II+ > Marantz PM66 KI > Mission 794
Also cluttering-up the place:
Thorens TD160 no cartridge; Marantz CD63 mkII KI; Technics SL-P777; Cyrus 2 + PSX; Cyrus Tuner; Nakamichi DR-1
The_Lhc
The_Lhc's picture
Buy a cheap DVD player with HDMI and use another HDMI input leaving the SCART free for the VCR, maybe?
__________________
No signature worth mentioning...
RipFi
RipFi's picture
I suppose your dvd-player has component output (green,red,and blue rca sockets).If so, use them instead of scart.
MajorFubar
The SCART to RCA adaptor recommended by the Prof and myself is going to be a bit cheaper than a new DVD player Wink The fella wanted advice regarding how to connect the gear his mum-in-law's already got to her new telly, not to be told that she needs a new DVD player Tongue
__________________
The_Lhc
The_Lhc's picture
Probably not by much, have you seen what DVD players cost now? He'll need the cable as well don't forget... EDIT: AND your suggestions are assuming the TV has the required sockets for your option, at least I know the TV will have two HDMI inputs.
Just giving another option that needn't be expensive.
__________________
AnotherJoe
AnotherJoe's picture
You'd get more precise answers if you actually gave the model numbers of the kit involved.
__________________
Server Synology 8Bay DS1812+, Synology 4Bay DS412+, Sky+HD
Lounge Samsung UE55D9000, Denon DBT-3313, Onkyo TX-NR5009, Tannoy Arena Highline 500 LCR, ACRyan playon!HD mini2
Reception Samsung UE46C8000, Panasonic BDP310, Sony STR-DA5400ES, KEF2005.3, ACRyan playon!HD mini2
The_Lhc
The_Lhc's picture
Yeah but where's the fun in that eh?
__________________
Big Chris
Big Chris's picture
Get her a Blu-Ray instead. Smile
__________________
Hi-Fi: Arcam A85, P85, CD192. B&W 602S3, PV1, Grado SR125, Atlas Titan, Hyper 2.0.
A/V: Sony KDL-V40A12U, BDP-S760, Humax Youview, Onkyo TX-SR875, B&W MT30 7.1, QED HDMI-P, S.A XT
Big Chris
Big Chris's picture
Cor! You want the moon on a stick you do! Smile
__________________
Son_of_SJ
Son_of_SJ's picture
I don't think that any new TVs that have more than one SCART input are being made. (But my 2009 Pioneer TV has three SCART inputs!)
Yes, they are reliable. Something like the first two that come up with this link from Maplin http://www.maplin.co.uk/productsearch?criteria=SCART%20Switches  I use the 3-way switch box (the one currently at £15.99) in my parlour to select between the SCART outputs of my Freesat box, the DVD player and the analogue outputs of the Blu-Ray player.
These are manual switches, you have to press a button to select input A, B or C. As professorhat says, there are others that do automatic selection, but I'm not sure who sells them.
Cass
Cass's picture
Thanks for the responses, guys - all much appreciated. I'll try the SCART-RGA cable, which I think would be the easiest set-up for my somewhat technophobic  MIL to operate, as the various sources can be clearly named on the TV's input selection menu.
As regards kit model nos, I don't have them to hand and I'm not sure it would have helped much - the items are real bargain-basement stuff (I recall the DVD being a Technika), and both are over ten years old - closer to 20 in the case of the VCR.
__________________
