6 posts / 0 new
Last post
cheyworth's picture
Last seen: 11 hours 51 min ago
Ceiling Mount
Could someone recommend a good ceiling mount for my Infocus IN80, to give 20-30cm between ceiling and projector.
Bryston CD1, Leema Tucana 2, Hydra 1, Monitor Audio PL300.
Plus home cinema stuff
D.J.KRIME's picture
Last seen: 3 years 4 months ago
RE: Ceiling Mount
Anything regarding PJs on here tends to get very few replies and post can gather a few cob-webs! Anyway does your PJ require a 3 or 4 arm mount?
cheyworth's picture
RE: Ceiling Mount
Hi, its a 4 arm mount thats needed.
Chris
TheHomeCinemaCentre's picture
Last seen: 3 years 1 month ago
RE: Ceiling Mount
We use the Premier Mounts Nova EXT ( aka  SPi-Ext) with good results.
D.J.KRIME's picture
RE: Ceiling Mount
You could go for one like THIS
DandyCobalt's picture
Last seen: 1 year 9 months ago
RE: Ceiling Mount
I was going to go for one of these, with extension, but my Sony projector didn't have enough vertical shift...
http://www.kenthomecinema.co.uk/Omnimount-WM3-PJT.htm
I eventually had a bookcase made for my DVDs/BDs with a higher semi-shelf on top to rest the projector on. It sits behind us.
Log in to post comments
